How can I check the existence of block by command?
Hello.
I'm making a macro program.
This function needs a block and if there's no block, the function doesn't work and block form pops.
So, I want to put in a command which checks the existence of block before main commands.
But I couldn't find the command or parameter.
Eventually, I check the type of the block and check its scalar parameters.
For example, if the type is 'box' then check X, Y and Z lengths are larger than 0 or not.
But I think this way is bizarre and not clean.
If there is a way to check the existence of block more cleaner, please let me know.
I would be glad if you reply.
Thank you.
