How can I check the existence of block by command?
ikims1126
ikims1126
Hello.
I'm making a macro program.
This function needs a block and if there's no block, the function doesn't work and block form pops.
So, I want to put in a command which checks the existence of block before main commands.
But I couldn't find the command or parameter.
Eventually, I check the type of the block and check its scalar parameters.
For example, if the type is 'box' then check X, Y and Z lengths are larger than 0 or not.
But I think this way is bizarre and not clean.
If there is a way to check the existence of block more cleaner, please let me know.
I would be glad if you reply.
Thank you.
kevin.hammond3WX4X
Try this........
string BLK_TYPE = ""
$BLK_TYPE = block.type
REAL $X_range = $block.Limits.Xmax - $block.Limits.Xmin
REAL $Y_range = $block.Limits.Ymax - $block.Limits.Ymin
REAL $Z_range =  $block.Limits.Zmax - $block.Limits.Zmin
IF ($X_range == 0) {
IF ($Y_range == 0) {
IF ($Z_range == 0) {
Message warn "No block exists"
} ELSE {
message info $block.type
macro attached below, change .txt to .mac
