- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to improve programing time at my company through getting the guys onboard with macro programming as much as possible. I'm in charge of all the data prep (install fcs, coloring the model etc...) and macros. We have a 5axis machine that I would like to macro out drilling holes based on color. I've got it down to do 5axis toolpaths without issue, the problem is because of travel issues we frequently have to drill holes 3 axis instead. The problem I'm running into is naming the featuresets properly. For example if I'm drilling a part with dowel holes on both ends it will create a featureset for both ends but it only names one of them "dowels", the other will remain named "1" or whatever number is assigned. How can I get the macro to output the name "dowels" for one featureset and "dowels_1" for the second. This is what my macro looks like to make the featureset.
// DOWEL BLIND FEATURESET
EDIT SELECTION MODEL DELETE
EDIT SELECTION SMART NO FORM MODELSELECT
EDIT SELECTION MODEL FILTER "255, 128, 0"
EDIT SELECTION MODEL APPLY
FORM CANCEL MODELSELECT
EDIT FEATURECREATE TYPE HOLE EDIT FEATURECREATE CIRCULAR ON EDIT FEATURECREATE FILTER HOLES EDIT FEATURECREATE TOPDEFINE ABSOLUTE EDIT FEATURECREATE BOTTOMDEFINE ABSOLUTE FORM CANCEL FEATURE FORM CREATEHOLE
EDIT FEATURECREATE HOLES FIXED ON
EDIT FEATURECREATE HOLES DIRECTION BOTH
EDIT FEATURECREATE CREATEHOLES
RENAME FEATURESET ; "DOWELS BLIND"
FORM CANCEL CREATEHOLE
UNDRAW FEATURESET ALL
DEACTIVATE FEATURESET
Here's what it looks like to run the drilling method
// CHOOSE MATERIAL
STRING ARRAY MATERIAL[] = {"ALUMINUM", "STEEL", "DELRIN"}
INT $STOCK = INPUT CHOICE MATERIAL "CHOOSE A MATERIAL TO DRILL"
IF $STOCK == 0 {
// DRILLS TAPPED BLIND HOLES
ACTIVATE Featureset "TAPPED BLIND"
IMPORT TEMPLATE ENTITY TOOLPATH TMPLTSELECTORGUI ""
EDIT METHOD APPLY
DELETE TOOLPATH "1"
Any help would be appreciated, bigly.
