Help !!! error access violation - code c0000005
stipsrl
stipsrl
I am having some issues with PMill - ERROR: Access Violation - code c0000005 (first/second chance not available). Not all my projects crash, but most of them do. I am attaching a pic regarding the error I get along with the error log, if anyone has ever had this issue and knows a fix, please let me know.
Greetings
lokesh.kalia
Hello @stipsrl
I'm sorry you are seeing these errors. From the information provided I cannot tell what the problem might be. If you could you give me the error report number from one of the crashes I'll be able to investigate further.
Thanks.
Lokesh Kalia
Senior Manager, Software Development
stipsrl
hello, thank you for the answer, this is the report number: 335940326.
if you can give me an answer because the situation is becoming more and more critical
lokesh.kalia
Hello @stipsrl .
Thanks for the report number. Are you interacting with fields on the Start Point and/or End Point pages of a toolpath strategy form? - We are aware of an issue when interacting with these fields directly (i.e. by clicking in a field and setting a value) having re-raised the form. This can result in a crash.
Is this your experience too?
If so, I think you could avoid the crash by setting Start Point and/or End Point values via commands instead.
Alternatively, you might prefer to roll-back (uninstall) the  latest update and revert to PM 2023.0.3 instead.
A fix for this problem has been implemented and is intended for PM 2023.1.1.
Lokesh Kalia
stipsrl
hello mr.Lokesh,
thanks for the solution you recommend, I assume it refers to version 2023.1 because we have that version, we have seen that the problem occurs with projects created with CATIA, I don't know if it could depend on this, now we are working with projects created with CREO and the problem hasn't recurred so far.
thanks for your time .
lokesh.kalia
Thanks @stipsrl . You are quite right, my comments were with regards to PM 2023.1 . I have amended my post accordingly.
I'm surprised that the occurrence of the crash would depend in that way, but I'm glad to hear you have found a way to  overcome this problem. 🙂
Lokesh Kalia
stipsrl
Abbiamo eseguito roll-back alla versione 2023.0.3 e per ora il problema non si sta presentando.
Grazie
