Guidance for Centrifugal Impeller/ Blisk toolpath
204100013
Observer Observer
204100013
Observer
Observer
Hello All, I wanted guidance to create PowerMill programs for machining an Impellar I have created a shroud by taking an offset of the outer geometry of the impeller, created levels by acquiring the left blade, right blade shroud etc, but not able to generate a toolpath kindly help. I have attached the model I am using as SolidWorks file.
andrea_pomi
you can attach the project? I'm pretty sure that you made mistake in the options on the path. Anyway i'm attaching one photo for my project.
Observer
Observer
Hello, Thanks for the reply the project size was too big to opload so I have uploaded here 'https://iitbacin-my.sharepoint.com/:f:/g/personal/204100013_iitb_ac_in/EjLdBlTOKfFHlUDlvVWlNFgBcqVDb...' . Somehow I managed to make a toolpath out of it, but the program coming out is almost 300 hrs long. While using ball end tool of 6 or 8 mm it is giving error. So if possible kindly go through the project will be great help.
andrea_pomi
i will take care about it.
Thanks you
