get toolpath selected folder names
hx
hx
Get use command to return the names to a list which was selected in toolpath tree nodes?
I only know a workaround for this problem: https://forums.autodesk.com/t5/powermill-forum/getting-then-selected-folder-name/m-p/8497952
The attached macro attempts to find the name of the selected folder in four ways:
1.use active_folder() function
2.use explorer_selected_entities() function
3.use active toolpath
4.select by list
ENTITY LIST SelectedToolpaths={}
STRING SelectedFolder=''
IF active_folder() != "" AND substring(active_folder(),0,8) == 'Toolpath' {
  $SelectedToolpaths=folder(active_folder())
  $SelectedFolder=active_folder()
} ELSE {
  ENTITY LIST SelItems=explorer_selected_entities()
  IF size($SelItems)>0 AND $SelItems[0].RootType=='toolpath' {
    $SelectedToolpaths=folder(dirname(pathname($SelItems[0])))
    $SelectedFolder=dirname(pathname($SelItems[0]))
  } ELSEIF entity_exists('toolpath','') {
    $SelectedToolpaths=folder(dirname(pathname(entity('toolpath',''))))
    $SelectedFolder=dirname(pathname(entity('toolpath','')))
  } ELSE {
    STRING LIST FolderList=get_folders('toolpath')
    INT I=INPUT CHOICE $FolderList 'Please select folder'
    IF error($I) {
       RETURN
    $SelectedToolpaths=folder($FolderList[$I])
    $SelectedFolder=$FolderList[$I]
STRING LIST FolderList=get_folders($SelectedFolder)
  IF size($FolderList) > 0 {
    ENTITY LIST UnselectToolpaths={}
    FOREACH F IN $FolderList {
      $UnselectToolpaths=$UnselectToolpaths+folder($f)
// subtract not working with entities: $Diff list is equal with $SelectedToolpath
    ENTITY LIST Diff={}
    $Diff=subtract($SelectedToolpaths,$UnselectToolpaths)
// subtract working with strings
    STRING LIST L1=extract($SelectedToolpaths,'Name')
    STRING LIST L2=extract($UnselectToolpaths,'Name')
    STRING LIST L3=subtract($L1,$L2)
    $SelectedToolpaths={}
    FOREACH item IN $L3 {
      INT I=add_last($SelectedToolpaths,entity('toolpath',$item))
FOREACH tp IN $SelectedToolpaths {
  print=$tp.Name
Genericxg
Is the folder displayed like this
phocvet
I WISH TO GET THE NUMBER OF TOOLPATH IN 1 LIBRARY
