get cut direction of toolpath macro
bfaberBB7MX
bfaberBB7MX
Im having some issues with a macro to determine if a tool path is set to climb or conventional. It seems like regardless of what I select in the toolpath setting window running print $toolpath.cutdirection always returns climb. Is there another way to get the direction of cut for a toolpath?
Sean571
It worked for me. Maybe you are trying with an Area Clearance toolpath? Or you haven't hit Okay or calculated the toolpath. If you just change the cut direction but don't hit okay on the toolpath then it won't update.
If it is an Area Clearance Toolpaths you have two different types of cut direction, "profile" and "area" and "area" uses the $toolpath.cutdirection parameter, but "profile" uses the $toolpath.AreaClearance.Profile.CutDirection parameter
Sean Wroblewski
Applications Engineer
bfaberBB7MX
I should have probably narrowed it down a bit, in a curve profile path it will read climb regardless of the tool path setting. It does read correctly for a constant z path.
I guess thinking about it more if the toolpath is reversed after calculation, I wouldn't get the correct result anyways...
Sean571
That's because the Curve profile toolpath is actually considered an Area Clearance toolpath. Just by having echo commands on and the command window open you can see that when you change the cut direction. So you are using the wrong parameter.
Sean Wroblewski
bfaberBB7MX
ahh I see. would have never guessed that. Im assuming there is no way to get the cut direction if it was reversed after calculation?
bfaberBB7MX
Another question for you. Is there a more elegant way to figure out if a toolpath uses .cutdirection vs .areaclear.profile.cutdirection in the macro? I guess the sledge hammer approach is to just do a bunch of 'or' statements with all of the different types of toolpaths that use each, but there has to be a better way.
bfaberBB7MX
Disregard that last reply, I found that the active() function solves my issue.
