Font Display
Font Display
dsmits
Font Display
dsmits
Just wondering if anyone has seen this when backspaceing in an text area.(description on a tool)
im Leaning towards a Graphic card setting because im running on a virtual desktop and have no issues but all our programmers have physical systems. nothing is really poping out at me that looks different then my settings.
iamcdn79
Are you using an Nividia graphics card with the global preset set to 3D App - Visual Simulation?
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
dsmits
Its Nvidia RTX 2000 Ada Generation
had it at Base Profile and i did try switching it to 3D App - Visual Simulation
even tried messing with a few settings in
"C:\Program Files\Autodesk\PowerMill 2025\sys\misc\graphics.con" but no luck
just really odd it only does it in the Tool Description page
works fine in all other text areas like Toolpath notes and descriptions.
artur.boszczyk
This most likely relates to latest windows 11 update 25H2, which was installed on 16/‎10/‎2025 on my machine. Dont worry - PowerMill is not only
taget. Below image from Alphacam 2025 experiencing same problem. All worked fine till last 2 weeks.
I dont think the graphical card is to blame, but do you have Intel Arc Graphics which cotrols your display on your laptop (run dxdiag)?
iamcdn79
When was the last time the driver was updated? Trying doing that if it's been awhile.
Windows 11 Pro
artur.boszczyk
I’m using the drivers released in August 2025, and I don’t recall updating them manually, so unless Windows updated them automatically, the graphics drivers I’m using should be the same ones that worked fine before, as well as the ones in use when the text editng issue appeared.
artur.boszczyk
Windows update KB5068861 (November 11, 2025) fixed the issue.
