filter function confused
hx
hx
About the filter function.
I use the filter function to get toolpaths which is set rest.active.
ENTITY LIST EntityToolpaths = filter(folder('Toolpath'), 'AreaClearance.Rest.Active==1')
But when I use filter to the toolpath which where use specify tool, it raise error infor.
Can somebody tell me why.
ENTITY LIST UseToolToolpaths = filter(folder('Toolpath'), "Tool.Name=='1'")
How can I to get the toolpath list which was use the tool 1.
ENTITY LIST UseToolToolpaths = filter(folder('Toolpath'), "Tool.Identifier=='1'")
Problem: The Tool.Identifier  not necessarily unique...
urizenYHS3W
The problem that you'll have is if one of the toolapths' doesn't have a tool. In such cases '"Tool.Name' will raise an error.
Try something like:
ENTITY LIST UseToolToolpaths = filter(filter(folder('Toolpath'), 'entity_exists(Tool)'),"Tool.Name=='1'")
the inner filter will return a list of toolapths that have a tool to the outer filter which then returns just the toolpaths that use the Tool named '1'.
