feature set slot finishing toolpath goto rapid every step
amberg47
amberg47
slot machining.PNGhello anybody when i make feature set slot finishing program its goes to rapid movment when take next stepdown.
can any one help me to control spare rapid movement in this program?
for more understand please follow image
Replies (8)
iamcdn79
You probably have your 1st choice links set to safe. Change it to circular arc or on surface
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
amberg47
2018-03-12.pngno
no effect
iamcdn79
Your pic shows 1st choice as safe and 2nd choice set as on surface, make 1st choice set as on surface and 2nd choice as safe or skim
Windows 11 Pro
amberg47
2018-03-12 (1).pngplease check this 1 and its no change made in toolpath movements
iamcdn79
check the box on where it says  apply constraints
Windows 11 Pro
Sudhira
Autodesk Support
Autodesk Support
Is your issue is resolved or you are still looking for more ideas ?
If you need support, please attach the PowerMILL project.
BR,
Sudhira Dora
Sudhira Dora
amberg47
here is i attach a project file and please open it and help me
thanks
Sudhira
Autodesk Support
Autodesk Support
thanks
Hi Amberg,
Thanks for your feed back. I looked your project and concluded that you are intentionally cut the CAD part, so that the toolpath highlight as red color i.e. not safe. So first unchecked the Gouge option in Toolpath connection tab. In short links choose On Surface. For more info, please see the attached video as well as the revised project. Expect this will resolve your issue.
Video Link: http://autode.sk/2Hwofjp
If you will satisfy with my support, please accept the solution.
BR,
Sudhira Dora
Sudhira Dora
