export tool data to excel table
roberto_perez
roberto_perez
good morning
I have a macro that is used to import into powermill a list of tools that has previously been filled in in an excel table. This table is made up of all the data that the tool needs to have the different components, reference, family, tip data, shank and even cutting conditions.
If someone had the same thing but in reverse, I would need a macro to export all the data that makes up this tool to Excel. please look at the table to understand.
attached example table and macro
Thank you
kevin.hammond3WX4X
Hi, i don't have the time to give you all that you are asking for, but see the attached file, this will get you started.
Hope this helps.
Please share your final macro, as it may be of use to others.
Regards Kevin
roberto_perez
hello. unfortunately I have no programming knowledge, I would gladly share it with all members, but I don't know how to do it
Thank you
Michaelangelo631
@Anonymousposted about a  macro that will export all your tool info as a text file.  If you import this into excel with some formatting you can get close to what you are looking for.  This is not a full solution but a partial step in the right direction.
https://forums.autodesk.com/t5/powermill-forum/export-tool-database-in-csv/td-p/9289962
Mike
roberto_perez
@Michaelangelo631
Thanks, I was looking at it but it doesn't get all the component fields
