enlarge stl file??
enlarge stl file??
wm_pm
Message 1 of 12
enlarge stl file??
wm_pm
Hi, Is there a way to make a stl file, for example, 1mm larger with PowerMill or PowerMill modeling? I know it works with PowerShape, but I do not have the necessary PowerShape license.
Replies (11)
Message 2 of 12
iamcdn79
Yes, you can use the scale option in Powermill
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 12
wm_pm
hello, thanks first for the answer, but that does not seem to work in mm ...
Message 4 of 12
iamcdn79
What happens in mm?
If it is using imperial values convert your value from mm to inches. Ex) 4 mm use .157 or input the value in the box by 4/25.4
Windows 11 Pro
Message 5 of 12
richard.pedley
The scale value box typically uses a proportional value, ie a value of 0.5 in the scale box will half the size of the model, a value of 2 will double it.
The box can also handle expressions, for example, you can enter 14/13 in the box if you wanted to scale something from 13mm high to 14mm high.
Hope that helps
Richard
Richard Pedley
Research Engineer
Message 6 of 12
urizenYHS3W
Don't use the GUI if you need to scale in all directions. Use the SCALEALL command:
TRANSFORM SCALEVALUE "14/13"
TRANSFORM TYPE SCALEALL TRANSFORM MODEL "my-model-name"
Message 7 of 12
wm_pm
hello, with the scaling seems to work, but the component is then only at the maximum size of 1mm larger, but I would like it everywhere uniformly 1mm larger, which seems to work with scaling not 100%
Message 8 of 12
craig.chester
Scaling the model will not provide you with a constant offset. Unless your model is super simple, like a sphere 🙂 So I do not believe that this is a viable solution for you.
Can you explain WHY you want to apply a constant offset to the model?
A possible workaround is:
  • Create a (Bi-Directional raster) toolpath with a 'small' ballnose tool and a THICKNESS equal to your desired offset, perhaps 1mm.
  • In VIEWMILL, simulate this toolpath
  • Export your VIEWMILL model to STL
This will create a new STL with your desired offset. It will not be perfect as:
  • Internal corners will have a minimum radii = tool radius
  • The model will include 'cusps' generated from the toolpath. So you may want to use a small stepover to control this inaccuracy.
Or................. A very similar method will be:
  • Create a new STOCK MODEL, ensuring it is big enough to encase the whole part
  • Create a 'small' ballnose tool
  • On the stock model > APPLY ACTIVE TOOL LAST - Enter your offset value into the AXIAL and RADIAL thickness
  • CALCULATE the stock model
  • EXPORT the stock model as STL
I do not know if this is useful as I don't know WHY you want to do this.
Message 9 of 12
wm_pm
Our work processes look like this:
Roughing around with 2-3mm oversize, then the components go to harden.
after hardening is finished.
Due to the hardness delay my existing STL in practice no longer true.
Therefore I urgently need the option to enlarge stl files, so to speak inflate
Message 10 of 12
wm_pm
hello together, I just wanted to address this issue again and ask if maybe someone has a solution.
Message 11 of 12
craig.chester
I assume you are not happy with the response I gave earlier? Does this method not work for you?
Message 12 of 12
wm_pm
I would like to enlarge a stl file evenly with a certain mm indication. for example 1mm.
when I scale, it is unevenly magnified. only if I have a sphere or a rectangle or something similar would it work with scaling. i have stl dates that are complex, when i scale, i have reached the maximum I want the value i want, but in the contours it is less then. I just want it evenly piled up, which is for example 1mm more material everywhere.
