When I edit multiple NC programs for "Verification/ Machine Tool Clearance" (working in inches) it only allows me to set a minimum clearance of 1.0" anything under that it defaults to 0."
Hi @BWARNERDXF5K,
I have conveyed this behavior to development team. I will update you on this.
You can set the value less then 1 for "Machine Tool Clearance" as per your requirement by Right clicking on specific NC Program and selecting the "Verify" context menu.
Hope this helps.
@BWARNERDXF5K wrote:
Also right above it I cannot "check/un-check" "Verify connection moves"
Hi @BWARNERDXF5K,
I have tried this at my end with PowerMILL 2018 Hotfix 3 cb1212121 and I was able to check/uncheck "Verify Connection Moves" under Verification tab. Please have a look at the small video:
Can you make sure you are using the latest release (codebase 1212121) of PowerMILL 2018?
Thanks and Regards,
