PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Edit Cutting Data Macro Help
11 REPLIES 11
Message 1 of 12
evo80
483 Views, 11 Replies
IF $powermill.Status.MultipleSelection.First OR $powermill.Status.MultipleSelection.Total == 0 {
reset localvars
DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	GRAPHICS LOCK
	if size(explorer_selected_entities()) <= 0 or explorer_selected_entities()[0].RootType != 'tool' {
		return
    REAL $feedspeed = INPUT "Enter Type & Operation"
	REAL $speed = INPUT "Enter Cutting Speed"
	REAL $feed = INPUT "Enter Feed/Tooth"
	foreach $t in filter(explorer_selected_entities(),'this.RootType == "tool"') {
	EDIT TOOL FEEDSPEED SELECT $feedspeed
    EDIT TOOL $t SURFACESPEED $speed
	EDIT TOOL $t FEEDPERTOOTH $feed
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	GRAPHICS UNLOCK
Good Day,
I have this macro which allows me to change the Speeds and Feeds of selected tools.
The only thing I have an issue with is the Type and Operation $feedspeed.
Currently I have to input 0 0 for Finishing General or 0 1 for Finishing Slotting and so on.
What I'd like is to have a drop down with all the Types and Operations to select from, but I'm not entirely sure how to go about doing this, any help would be much appreciated.
Regards
11 REPLIES 11
Message 2 of 12
icse
in reply to: evo80
heres a simple example what you could do:
string list $operations = {'General', 'Slotting','Profiling', 'Face Milling', 'Drilling', 'Plunge Milling', 'Copy Milling'}
int $feedspeedIndex = INPUT choice $operations "Enter Operation"
	EDIT TOOL FEEDSPEED SELECT 0 $feedspeedIndex
you macro should look something like this then:
	reset localvars
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	GRAPHICS LOCK
		return
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	GRAPHICS UNLOCK
Message 3 of 12
evo80
in reply to: icse
@icse
	reset localvars
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	GRAPHICS LOCK
		return
    string list $types = {'Finishing', 'Roughing'}
	int $feedspeedIndexType = INPUT choice $types "Enter Type"
    string list $operations = {'General', 'Slotting', 'Profiling', 'Face Milling', 'Drilling', 'Plunge Milling', 'Copy Milling'}
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	GRAPHICS UNLOCK
Splendid,
Now how do I distinguish between Roughing and Finishing?
I came up with the above but am unsure how to apply.
Message 4 of 12
icse
in reply to: evo80
Pretty much the same as above, you just need anoter list with the options and anoter variable wich stores the value
Message 5 of 12
evo80
in reply to: icse
So I have two indexes, one for the data type and one for the operation, and they're outputting the correct values,
I'm just unsure how to put both those values on the same line as
EDIT TOOL FEEDSPEED SELECT.
The code below fails.
	reset localvars
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	GRAPHICS LOCK
		return
	EDIT TOOL FEEDSPEED SELECT 0 $feedspeedIndexType + $feedspeedIndex
	PRINT $feedspeedIndexType
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	GRAPHICS UNLOCK
Message 6 of 12
icse
in reply to: evo80
EDIT TOOL FEEDSPEED SELECT ${feedspeedIndexType} ${feedspeedIndex}
Message 7 of 12
evo80
in reply to: evo80
Cheers, Now it works great
	reset localvars
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	GRAPHICS LOCK
		return
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	GRAPHICS UNLOCK
Message 8 of 12
evo80
in reply to: evo80
@icse
Sorry to be a pain but could you tell me why my coolant choice is failing?
	reset localvars
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	GRAPHICS LOCK
		return
	STRING list $Coolanttype = {'None', 'On', 'Thru'}
	STRING $C = INPUT CHOICE $Coolanttype "Enter Coolant Type"
	$C = $Coolanttype
	PRINT $C
	EDIT TOOL $t COOLANT $Coolanttype
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	GRAPHICS UNLOCK
Message 9 of 12
icse
in reply to: evo80
try this:
	reset localvars
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	GRAPHICS LOCK
		return
	STRING list $Coolanttypes = {'None', 'Standart', 'Flood', 'Mist', 'Tap', 'Air', 'Thru', 'Both'}
	int $index = INPUT CHOICE $Coolanttypes "Enter Coolant Type"
	string $Coolanttype = lcase($Coolanttypes[$index])
	EDIT TOOL $t COOLANT ${Coolanttype}
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	GRAPHICS UNLOCK
Message 10 of 12
evo80
in reply to: icse
Strange,
It's returning the correct coolant type when I PRINT $Coolanttype but fails with this in the command window.
**** EDIT TOOL $t COOLANT ${Coolanttype}\n
**** --------------------^ Unexpected input !!
Error in Network : tool ( CoolantCmd )
Last Valid Token : COOLANT extracted by graph [ COMMAND ]
Received input : " ${Coolanttype}\n"
I tried without the curly brackets but got the same result.
Message 11 of 12
icse
in reply to: evo80
oh ok you could try:
string $cmd = "EDIT TOOL '" + $t.Name + "' COOLANT " + $Coolanttype
docommand $cmd
or
$t.Coolant = $Coolanttype
insted of:
both should work
Message 12 of 12
evo80
in reply to: evo80
Many thanks,
I used the 2nd option,
Here's the working Macro.
	reset localvars
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	GRAPHICS LOCK
		return
	STRING list $Coolanttypes = {'None', 'Standard', 'Flood', 'Mist', 'Tap', 'Air', 'Thru', 'Both'}
    PRINT $Coolanttype
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	GRAPHICS UNLOCK
