Delete bottom part of boundary automatically?
johnc4668
johnc4668
Fellas,
Looking for a way to delete this bottom section of boundary automatically with no user intervention using colors and a user boundary. I want to select the color on the inside of this pocket or pockets and just use the top section.
ondrej.mikulec
try this:
FUNCTION Main() {
	ENTITY $bound = entity('Boundary','')
	INT $count = segments($bound)
	INT $targetIndex = -1
	REAL $targetZMax = 0
	WHILE $count > 0 {
		$count = $count -1
		EDIT BOUNDARY ; DESELECT ALL
		EDIT BOUNDARY ; SELECT $count
		REAL $zMAx = 0
		CALL GetZMax($zMAx)
		IF $zMAx > $targetZMax {
			$targetIndex = $count
			$targetZMax = zMAx
	IF $targetIndex > -1 {
		WHILE $count > 0 {
			$count = $count -1
			IF $count != $targetIndex {
				DELETE BOUNDARY ; SELECTED
FUNCTION GetZMax(OUTPUT REAL $zMAx) {
	EDIT BLOCKTYPE BOX
	EDIT BLOCK COORDINATE WORKPLANE
	EDIT BLOCK ALL UNLOCK
	EDIT BLOCK LIMITTYPE BOUNDARY
	EDIT BLOCK RESET
	EDIT BLOCK LIMITTYPE MODEL
	$zMAx = $Block.Limits.ZMax
nguyenthinhvt95
@johnc4668
I would like to suggest a macro code to get the top section. Hope this's work.
INT $i = 1
EDIT BOUNDARY $bound.name CURVEEDITOR START
CURVEEDITOR REORDER SORT STARTZ
WHILE $i  < $count {
CURVEEDITOR REORDER LISTUPDATE\r 0 NEW
CURVEEDITOR DELETE SELECTED
$i = $i + 1
CURVEEDITOR FINISH ACCEPT
johnc4668
@nguyenthinhvt95
This worked great! But it wants to delete every boundary except one. Im looking to keep all the boundaries at the top surface and delete anything below the top or below z zero.
Before:
After:
ondrej.mikulec
I changed things to:
The first loop finds the highest ZMax.
The second loop removes what's not in ZMax and keeps all that is.
The third loop goes through each segment, copying the boundaries for each one.
FUNCTION Main() {
	WHILE $count > 0 {
		$count = $count -1
		REAL $zMAx = 0
		CALL GetZMax($zMAx)
		IF $round($zMAx,3) > $round($targetZMax,3) {
			$targetZMax = zMAx
	WHILE $count > 0 {
		$count = $count -1
		REAL $zMAx = 0
		CALL GetZMax($zMAx)
		IF $round($zMAx,3) != $round($targetZMax,3) {
	WHILE $count > 0 {
		$count = $count -1
		COPY BOUNDARY ; SELECTED
	EDIT BLOCKTYPE BOX
	EDIT BLOCK RESET
johnc4668
I owe you a beer for this! thank you!! I'll take it from here!
