HELLO,
i HAVE A TOMBSTONE AND VISE WHICH I AM TRYING TO RECREATE AND COPY MY WORK HOLDING.
i HAVE DRAWN THE TOMBSTONE BY ITSELF ALSO ALL THE VISE PARTS IN POWERSHAPE. I HAVE CONSTRAINED IT ALL TOGETHER AND SAVED IT. WHEN I TRY TO IMPORT IT INTO POWERMILL IT COMES AS ONE OBJECT. HOW DO I BUILD IT IN POWERMILL SO I CAN CONSTRAIN IT AND HAVE THE VISE JAWS MOVING. ALSO, CAN I WRITE A MACRO MAKING THIS MORE SIMPLE?
THANK YOU.
HELLO,
THANK YOU.
I have never built full assemblies in Powershape so take this with a grain of salt;
In this example this is a typical Lang self centering vise;
The base is on it's own level. (Base)
The left jaw is on it's own level.(Left)
The right jaw is on it's own level. (Right)
When I import this model into powermill these level settings are retained and applied correctly.
I can now move the individual components with transform commands or work in a macro.
@Anonymous
I would do exactly what @mribble mentioned. Create the assembly in PowerShape and place each component onto a separate level. These levels will translate into PowerMill. You can then select all of the entities that reside on each level and transform how you need to using a macro.
You can do this with individual files as well. Exporting the assembly as separate cad files would be easy to transform as well.
@Anonymous
