Conical barrel tool support?
rdbojan
Message 1 of 11
rdbojan
Hi all,
Can someone tell me how can I define parabolic barrel tool with radius tip in PowerMill. I believe i need to draw the profile, but how can i exploit conical part of tool in 3- and 5-axis programming. Do i need to define lean angle or PowerMill can do it automatically?
I seen on YouTube that HyperMill have Tangential machining, adjusted operation for this kind of tools.
Replies (10)
Message 2 of 11
craig.shipley
Autodesk Support
Autodesk Support
Hi
You would create a form tool from the curve data (usually supplied by the tooling supplier).
From there you do need to build the toolpath and use lead/lean to tilt the tool to the required angle, there's nothing automatic as far as I know.
I have attached a sample project that may help get you started.
Kind Regards
Message 3 of 11
rdbojan
But, the conical part also have radius 500 or 1000 mm. This can't made with form.
I agree for the rest.
This kind of tool is good for finishing. You can add bigger stepowers and control tilt angle to avoid collision.
I hope that Autodesk Development Team will take this in consideration.
Message 4 of 11
craig.shipley
Autodesk Support
Autodesk Support
Hi
Do you have sample tool geometry?
As you can see in the image, the form tool in the project has a 250mm radius...
Kind Regards
Message 5 of 11
anbu.kumar
Hi @rdbojan
Thank you for posting in forums.
Please have look in to attached video & I think it's also helps you to create a Parabolic Cutters.
And refer @craig.shipley post for auto tool axis.
Video link:       https://autode.sk/2nfhkmA
Thank you,
Anbu Kumar.
Message 6 of 11
rdbojan
Hi Craig,
It's my fault. I have forgotten that you used curve for defining tool, not just by adding spans in form tool - this way you can't put radius after radius.
So, everything is good.
Thank you for your help and fast answers.
Message 7 of 11
craig.shipley
Autodesk Support
Autodesk Support
Glad to help.
Kind Regards.
Message 8 of 11
Sudhira
Autodesk Support
Autodesk Support
@rdbojan wrote:
Hi all,
Hi  Rdbojan,
Thanks for posting in Autodesk Community!!!
I have added some more information for tangential machining with the help of Swarf finishing. You can use form tool or Tapered Spherical tool for machining. Please refer to the attached PowerMILL project.
If my post answers your query, please click on 'Accept as Solution' button.
Sudhira Dora
Message 9 of 11
rdbojan
Thanks Sudhira,
like I have wrote, point is that conical part of tool have big radius, so u can adjust tilt angle.
Thank you anyway for answering.
Message 10 of 11
M_Hennig
I have messed around with these a bit and I got them to work, sort of. I could get it to make the toolpath but could not adjust the contact point like Hypermill. I don't think PM is really equipped to utilize these tools properly.
Message 11 of 11
rdbojan
I agree.
Autodesk should take this into consideration for new strategies.
