Bottom Corner, toolpath avoids going into. Model Area Clearance
wwallhead
Message 1 of 27
wwallhead
Is there a setting in Model Area Clearance that I can change to get the toolpath to go into the bottom corner?
The .jpg I attached shows how the bottom corner gets avoided by the toolpath.
The only way I can get what I want is to set the Block a few tenths shallower then the depth of the pocket, which is too time consuming.
Wayne
Accepted solutions (4)
Replies (26)
Message 21 of 27
wwallhead
I need help finding where to do the 'Draw Model Trianges and undraw Model Triangles'.
Message 22 of 27
iamcdn79
You either can make a text file and save it as a .mac file or you can select tools from the top of the screen and select echo commands and type it in there
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 23 of 27
j.lacrasse
Hi @wwallhead
to draw and undraw model triangle you need to go to the top menu draw than model than clic ctrl-tab. It will display what you want.
Cheer
J.Lacrasse
J.Lacrasse
Message 24 of 27
wwallhead
I just tried this and it worked for me.
Like you said 'machine down to flats checked' then I changed mine from area to level and it worked, Automatically.
Automatically.
I am good.
Thanks everyone.
Let me know if this works for you, if you want.
Message 25 of 27
This is what the majority of mine look like
Message 26 of 27
wwallhead
Area vs Level in Model Area Clearance
In Constant Z Finishing - Machine down to flat - my test never makes toolpath into the corner.
I didn't find anything to do in there that would be helpful.
If it is an algorithm thing maybe Delcam can do in Constant Z Machine down to flat what happening in Area Clearance Level.
Message 27 of 27
wwallhead
If this is the best solution. Maybe more testing is needed.
Anyway I created a Case.
Case ID: 12287332.
Fix Constant Z Finishing Machine down to flat so toolpath in the bottom corner is one point.
