Autodesk PowerMill 2019.1 Update is now available for download
dillon.moulder
Alumni Alumni
Message 1 of 18
dillon.moulder
Customers using any product from the PowerMill 2019 range with an active subscription or maintenance plan can now download and install the PowerMill 2019.1 Update through the Autodesk Desktop App:
Alternatively, you can download the PowerMill 2019.1 Update from the Product Updates area of your Autodesk Account. The associated PowerMill_2019.1.exe file is 84.4 MB (88,584,192 bytes) in size on disk.
Details of the fixes and enhancements included in the PowerMill 2019.1 Update are listed here.
To confirm that you've successfully installed the PowerMill 2019.1 Update, select the ? > About menu option in your PowerMill 2019 software and check that you're working in Version: 2019.1.0.2019104.
You can download the latest version of the Autodesk Desktop App (7.0.10.89) from here.
Kind regards,
Replies (17)
Message 2 of 18
987459241
0.4 problem still exists, and some new problemsMan Sad
Message 3 of 18
dillon.moulder
Hi @987459241,
The Autodesk Community is a peer-to-peer network. Please report any issues that you encounter while working in PowerMill 2019.1.0.2019104 by creating and submitting a case from your Autodesk Account. That way, they can be assigned and investigated. Please ensure that you provide a screencast and files which can be used to reproduce your reported issues.
Thanks in advance for your time and cooperation.
Kind regards,
Message 4 of 18
zfreitas
Can you describe the new ones?
Best regards,
Jose Carlos Freitas
Tech Support Engineer
NORCAM
Message 5 of 18
iamcdn79
With the new 2019.1 update there have been some enhancements added. Attached are some interactive videos showing how to use these new features.
Enhanced Setups
Posts in the Cloud
Interactive Collision Avoidance
Probing
Pattern Turning
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 6 of 18
5axes
With the new release some machine configurations are not anymore valid. They were ok since several years but I got the following message :
Modification :  For such case I have change :
<machine xmlns="x-schema:PowermillMachineTool" POST="pmpMultiaxis.*">
to
<machine xmlns="x-schema:PowermillMachineTool" POST="WSModel.*">
and I can load them again in PMILL ??
Message 7 of 18
5axes
One Workaround in such case is to load an existing project with the machine , then export the machine under a new Mtd file.
It's interesting to notice that in such case Axis without priority are automaticaly saved Under the PRIORITY="MEDIUM"
and <dmt_file>  into  <triangle_file>
Message 8 of 18
5axes
As "usual" I would say since the release 2017 . New types of tool are added into the existing type of Tool in PMILL . But no one take time to update the database . So You can create the tool but not store it ! Smiley Frustrated
Message 9 of 18
5axes
With this release if for any reason you have calculate a toolpath using a SETUP + Clamp information, and then you decide to delete this SETUP. The information of thickness and the element are still present on the  layer 16 of the Component Thickness. And you cannot change the Thickness value.
Message 10 of 18
j.lacrasse
In setups,
The block definition under coordinate system has to be set on NAMED WORKPLANE. If it isn't when you calculate the toolpath, the coordinate system definition will change it to NAMED WORKPLANE and will use the workplane defined in SETUPS / SETTING/ WORKPLANE.
Pretty annoying
J.Lacrasse
J.Lacrasse
Message 11 of 18
5axes
yes agree with you @j.lacrasse,
Even if you have uncheck the option "Use Setup Stock"  As soon as you launch the toolpath calculation  PMILL change the Coordinate system of the Block to "Named Workplane"  and use the SETUP Workplane. namedWP.PNG
Message 12 of 18
j.lacrasse
Another thing which may only affect few users, is the NCsimul interface.
The new version is 3.0.14
It affects the clamps. Instead of transferng them as clamp is transfer as part.
Before importing into Ncsimul I change inside the .nxf file the status of my clamp
|UNITS|INCH|
|MATRICE_OXY|1.1E-05,0.339887,-3.295,0,-1,0,1,0,0|
|CLAMP|STL|JIG COLLET ER40 TRT100.stl| |
|ELEMENT_NAME|JIG COLLET ER40 TRT100|
Cheers,
J.Lacrasse
J.Lacrasse
Message 13 of 18
j.lacrasse
As simple as it is, changing opacity to the setup stock require the recalculation of items using it. Smiley LOL
J.Lacrasse
J.Lacrasse
Message 14 of 18
iamcdn79
I don't have that on my end
https://autode.sk/2oNjD13
Windows 11 Pro
Message 15 of 18
5axes
Hi @iamcdn79
You don't have the issue because your toolpath have certainly not be calculated in the SETUP. But as soon as you calculate the toolpath in the Setup , then you cannot change the  Opacity  you cannot shade or unshade the clamp or the toolpaths ..
https://autode.sk/2Ma1N1A
Message 16 of 18
Genericxg
I want to know where the fixture in your BBB 0 is. Can you share it? Thank you
Message 17 of 18
Benjamin.Br
Thank you for the feedback everyone is providing. We are listening.
Benjamin Brereton
Director, Engineering
Message 18 of 18
j.lacrasse
Hi all,
Looks like only levels can be use for component thickness in toolpath while using setup.
Anyone else has this issue?
J.Lacrasse
J.Lacrasse
