Align Workplane To Geometry With A Macro
danmic7JH66
danmic7JH66
I came across this post and I made some use out of the solution. One thing I haven't been able to get to work though is aligning a workplane to the geometry of each selected surface. I use the code...
MODE WORKPLANE_CREATE ; SELECTION CENTRE
to get a workplane off the surface but I can't seem to get it aligned properly with the code
MODE WORKPLANE_EDIT ALIGN GEOMETRY
Is this even possible without user input?
5axes
It looks like similar to this post ?
danmic7JH66
Never seen that one, Ill give it a whirl and report back, thanks!
danmic7JH66
Pretty similar and it helps, I understand how it gets the i,j,k values but is there a way to rotate a workplane along those values?
5axes
Use the command
MODE WORKPLANE_EDIT DIRECTION Z
MODE DIRECTION COMPONENT I $VectI
MODE DIRECTION COMPONENT J $VectJ
MODE DIRECTION COMPONENT K $VectK
danmic7JH66
You're a doll thanks a million.
