Add a line of content into .txt file.
nguyenthinhvt95
nguyenthinhvt95
I have a problem need your help:
I create a txt file to count how many file export per month to report to boss.
the structure of content line in .txt file (show in the picture):
"Number count" , "Path project" , "extra infomation".
At the moment I use foreach funtions to reach all line of .txt file and then use token by "," to get the final number.
It working well but it take really a long time to reach all line of .txt.
Is there any function that allows adding a new line of content to a TXT file, with the requirement that the added line must be on a new line compared to the existing content in the TXT?"
// DIALOGS MESSAGE OFF
// DIALOGS ERROR OFF
INT old_time = time()
STRING Link_txt = "A:\CAM\Macro\6.CSharp\5_All_in_one\Control\OpenPowermillFileData.txt"
STRING LIST $TXT_Data = {}
STRING LIST $TK_temp = {}
FILE OPEN $Link_txt FOR READ AS input
FILE READ $TXT_Data FROM input
FILE CLOSE input
int $OpenCode = 0
int Check_Variable =0
//Tao 1 noi dung moi tu file ban dau. Xoa khoang trang va nap vao bien text
string text = "Total line: " + $size(TXT_Data)
int dem = 1
CREATE PATTERN ;
ACTIVATE Pattern #
Foreach item In TXT_Data {
//Xóa khoảng trắng
if item != "" and $dem >= 2 {
$TK_temp = Tokens (item , ',')
// lay gia tri lon nhat
$Check_Variable = INT($TK_temp[0])
if OpenCode <= $Check_Variable {
$OpenCode = $Check_Variable
$Text = $Text + crlf + $item
$dem = $dem + 1
string PatternNameOLD= $entity('pattern', '').name
string PatternNameNEW= "Read line: " + $dem
RENAME Pattern $PatternNameOLD $PatternNameNEW
DELETE Pattern $entity('pattern', '').name
//===================Check the last number and + 1======================================
$OpenCode = $OpenCode + 1
//===================Gom chuoi cu va moi thanh 1 file vao dien vao file txt===================
//====================Date time :HH/MM/SS dd/mm/yy====================================================
INT tm=time()
STRING ARRAY $timestamp[] = tokens(utc_time($tm).timestamp, "-")
string hour = local_time(tm).hour
string date_full = $local_time(tm).hour + ":" + $local_time(tm).minute + "," + $timestamp[2] + "/" + $timestamp[1] + "/" + $timestamp[0] + "," + USER_ID()
//====================Date time====================================================
String value = $OpenCode + "," + $project_pathname(0) + "," + date_full
$Text = $Text + crlf + $value
//=====Write file again with updated=======
FILE OPEN $Link_txt FOR WRITE AS out
FILE WRITE $text to out
FILE CLOSE out
EDIT PAR 'project.Notes.' ""
EDIT PAR 'project.Notes.' $OpenCode
//=========================check total line and keep line the line ==============================
int SizeOfFile = size(TXT_Data)
//=========================input the number of line want to keep ==============================
int LineKeepNumber = 300
int Startline = SizeOfFile - LineKeepNumber
if SizeOfFile > LineKeepNumber {
FILE CLOSE input
$text = "Total line: " + $size(TXT_Data)
int dem_line = 1
if $dem_line > Startline {
$dem_line = $dem_line + 1
FILE CLOSE out
INT cumulative_time = time() - old_time
STRING msg = "Open code process took " + (cumulative_time) + "secs"
print $msg
DIALOGS MESSAGE ON
DIALOGS ERROR ON
icse
if oyu whant to append text to a file you use this:
string $filepath = "C:\test.txt"
string $txttoappend = "This should be added to the file as new line"
FILE OPEN $filepath FOR APPEND AS output
FILE WRITE $txttoappend TO output
FILE CLOSE output
if reading and handle entries in that file is to slow in the powermill macro language consider using a simple C# application.
nguyenthinhvt95
Hi @icse
You are right, I use method cmd to create a new .txt file and then I append this to the main txt file. This really fast.
Thank you for a suggestion.
