6 axis milling machine
Meysam_Ghorbani
Message 1 of 8
Meysam_Ghorbani
Hi
Is PowerMILL capable to execute 6-axis output?
can we generate 6 axis in this milling machine ?
Replies (7)
Message 2 of 8
iamcdn79
Sorry but unfortunately no. From what I have been told from postprocessor support Powermill can only drive 5 axis at a time, when you get to 6 or more axis you are dealing with robot machining
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 8
darren.connor
Autodesk Support
Autodesk Support
Hi HIGHCAMGROUP
The Autodesk manufactuting post processor utility (AMPPU) software is limited to 5 axis machining. You would be able to drive the machine, but not all 6 axes at any one time. Separate post processors would be required for each AB, BC configuration.
Message 4 of 8
we drive our 8Axis machine with LINUXCNC its capable of 9Axis syncron and max 12 axis Servo
it has kinetics for a Puma like DOF6
full ATC support and lots of Gui featers for self  construct at QTpyvcp level RT Kernel behavior
Message 5 of 8
Meysam_Ghorbani
so can you generate a 6 axis programming in powermill for these machine ?
Message 6 of 8
you do not need 2 do a 6axis
you can make a 3+2 or simply 5 and the kinetics goes for the coordinates itself
Message 7 of 8
Meysam_Ghorbani
yes i know we can programming 3+2 or 5 axis
just in robot machining we can programming More than 5 axis
anyway thanks
Message 8 of 8
Hi
Did you see the FreeCAD 9Axis robot extension interface
a Mill uses just the standard 6axis where ISO is clampt to 3liniar +- and 2 Rotation +-
as the part is fixed to a Axis line (4thAxis)or even a Plane
the Beethoven has been milled in 8hr as only 150mm toolcutlength it coudt have been 400mm as of 2 cuts insted of 8
the Toolpath is Rough at  XZC  made as Rotation Lathe
the finish is a 3+2 as XYZBC
If you need positining dont use a CAD /CAM use a Robot Util like  CUCA Free Pos
