- Mute
- Permalink
- Report
We just got custom made 5 axis CNC machine. I got machine kinematics in place and simulation for the test part is working properly. The problem is the post processor for Mach3. I have managed using instructions from this forum to create rudimentary 5 axis post from generic Fanuc using Autodesk Manufacturing Post Processor Utility but this somwhat works without RTCP while with RTCP if creates Gcode inconsistent with simulation.
The main difference is the Y coordinates with and without RTCP option post file. Without RTCP there is no fluent simultaneous movement of the machine it just rotates B axis for a long time before starting to use Z with minuscule movement while with RTCP gcode due to inadequate y distance it tool collides with B axis table.
The goal is to have truly simultaneous 5 axis movement as in simulation.
And this can be done by optimizing post for Mach3. Machine has manual tool change.
I will post .cut file with some .pmoptz post files with RTCP and without.
Can anyone help with adequate 5 axis simultaneous Mach3 postprocesor for this machine?
