How to Edit table_attach_point PART Direction in Manufacturing Post Utility to Match MTD File
ho-kou
ho-kou
hi everyone ,
I set the table_attach_point PART direction using the MTD file and want to set the same direction using the Manufacturing Post Utility. However, I am unable to edit the table_attach_point PART direction in the Manufacturing Post Utility.
How can I edit the table_attach_point PART direction to match the direction specified in the MTD file?"
serge.quiblier
Hello @ho-kou ,
you can try to export the kinematic defined in the post, via the button:
It will create a MTD text file.
You can modify it manually., and re import into AMPPU, using the <external> definition.
Regards.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Serge.Q
Technical Consultant
cam.autodesk.com
