Hi Wiktor,
Welcome to the PowerInspect Forum and thanks for posting your question.
So to answer your question, yes there are multiple ways to either add or exempt data from being explicitly sent to the report.
Are you wanting to remove the top part or are you looking to add in the extra information so that its the same as the bottom part of your image ?
- The first way is to explicitly check or uncheck the various report based export buttons by unchecking the blue page icon with a red strikethough on it.
The first image shows how various options can be excluded/included from the report for geometric features :
The second image below for surface inspections looks as follows which has its own dedicated report tab:
- The second method i mentioned involves Autodesk editing your report template so that the required information is either removed or added depending on your preference should the current options not suffice.
Depending on the amount of work required , this could be a cost option for you.
Let me know if this helps to answer your question ?
Kind regards
Kieran
Kieran Gill
Technical Consultant
