Alignment for flat product
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
My question may sounds very silly but I need a tip how to align the flat product. 2 mm thick, with no circles and cylinders. Profile looks pretty straightforward with two radiuses and two lines between them. I have a 3D model and I can't align the profile properly. Alignment lines are not matching with 3D module outline. They are laying on the module correctly but the line and arrow is out of the profile.
I have used a Wireframe Checker to select the surface and I have selected a Line between Two Points. I have aligned this part with PLP Alignment.
I tried to align this one with support of Rotation and Translation option on Edit Offset but I am still struggling to get a proper alignment.
I have tried to use Simple Measures to create alignment between Two Circles and Lines. Still doesn't work.
Profile is aligning pretty well on Non-Cad but we prefer Cad model to set the parameters once and then reproducing them on the next FAI.
How to overcome this problem? Is that is because of lack of circles, holes and cylinders?
Thank you in advance.
