How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
did you ever figure out how to get the program to recognize the feed speeds? The post processor I down loaded does work fib=ne. Previously using MADCAM, Mach 3 Metric post processer worked fine.
very thank you. your post is working well. can you guide me where I can learn more about post process? what they contains and how I can change there code for my needs?
Works great, but converts everything to metric, and we have to scale everything up by 25.4 any way to to have it post out in imperial?
Daniel
I doubt it converts to metric, it is natively metric.
Isn't it probably time you learned metric like the other 95% of the world?
Hi everyone,
I also have Weihong controller in my CNC router and I tried this post processor: "10717_Weihong NCstudio_with arcs.cps" but something's wrong. The machine works louder than normally when I use 2D CAD/CAM called Ucancam.
I think it's either wrong post processor or resolution of my machine (?) - maybe Fusion's tool path doesn't go with my machine.
Any ideas?
I recorded a short movie (with the spindle off) to hear better the machine moving along three axes.
I used 2D Adaptive Clearing. Smoothing: 0.01 mm.
I attach short movie clip and nc code.
Do you have any idea how to fix it?
Pawel
hello, i think problem is in smoothing, look at passes tab in toolpath menu, and look for enabled this option with a same number as a tolerance
maybe if you already enabled it, then problem may be in controller options
хотя, если по-русски читаете,мне будет проще объяснить)
Thank you. I think you're right. The same thing I heard from someone else yesterday. I used smoothing with default value of 0.01 mm which is probably too little and it makes the router to look for all these, close to each other, points on the tool path.
Do you recommend a better value for smoothing that won't cause this problem? I'll make some tests this weekend.
i think you should start a new topic with explanation your problem
mark me there
maybe it will interest someone else with a similiar problem
so my recommendation is something like this
if you input a stock to leave 0.5 mm so you may choose tolerance about 0.1 mm and smoothig 0.1 mm (there is something like a good rule choose smothing equal or greater than tolerance, but not smaller)
if you make no stock to leave then choose 0.01 tolerance and smoothing
it depends from what you need
i machining a steam turbine blade, so i need tolerances about 0.001 mm
but if you mill something like decorative vase you better choose tolerance like 0,05-0.1 mm for finish and about 0.5 mm for roughing(with about 1mm stock)
well, you still should look at controller preferences, maybe there is manufacturer options for smoothing, that conflict with your code
Thank you for your advice concerning proper smoothing values.
I'll also start a new topic about this issue.
Я еще не научились этому
I did not start a new topic.
The cause of the problem that I experienced was too tiny solid in which I tried to cut pocket. I did it only for testing, but it was too small, when I enlarged it, the problem disappeared.
This postprocessor works well with my CNC router.
My CNC router uses an NK105 G2 (not a G3). I downloaded the post you offered here and ended up with an error. It wouldn't process the path. Below is the error I'm getting. Is there anywhere to find a post to use with my model Weihong?
Error log:
Checksum of intermediate NC data: 43bdab6e8992f981d5359b225983ca16
Checksum of configuration: e1172929d066b15368ccc8164be0074d
Vendor url: http://www.autodesk.com
Legal: Copyright (C) 2012-2014 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.5331
Error: Tool orientation is not supported.
Error at line: 378
Error in operation: 'Drill2'
Failed while processing onSection() for record 308.
Error: Failed to invoke function 'onSection'.
Error: Failed to invoke 'onSection' in the post configuration.
Error: Failed to execute configuration.
Stop time: Tuesday, January 22, 2019 2:18:56 AM
Post processing failed.
hello
probably problem in axis of hole not alighned with z axis
check it
i think weihong uses g2 and g3 commands both
but you free to disable this function
Today I implemented a post for this machine. If anyone is concerned: I killed of all circular movements and replaced them by linear. Somehow the toollength (or just Z coordinates) were off by 8mm when using G2/G3. First I only killed G18/19 but later on also G17. I did not notice a difference in how fluent it runs but the machine seemed like it had pretty agressive deceleration settings, so maybe just not so visible.
2 parts were screwed because it machined almost into the table
Inventor HSM and Fusion 360 CAM trainer and postprocessor builder in the Netherlands and Belgium.
I am very interested in this. Is it published somewhere?
I'm not sure if that's what you mean, but here are two versions of manual and the post processor itself 🙂
https://www.weihong.com.cn/en/uploads/soft/160608/1-16060PUT0.pdf
https://am.co.za/router/panel/nk105.pdf
Thanks a LOT! it worked 🙂 I am using NK105 G2
Autodesk should include it on their HSM and Fusion360 products as default since it is very common now days to use such a controller.
Just two comments, on the post processor options use as follows:
1. Allow helical moves : NO
2. Use mm as unit. I noticed that if I have the file Units on inches, the cnc code will do smaller movements thinking you give it mm instead of inches.
Best regards,
How to buy
Type a product name
