Post Archive (Read Only)
Virtual Launch of BIM Tools
0 REPLIES 0
Message 1 of 1
sureshchotrani
382 Views, 0 Replies
Revit 2017
Make more informed design decisions, build more efficiently and cost-effectively, and manage and maintain buildings with greater ease using BIM. Reduce waste and increase profit margins with tools that help contractors and subcontractors plan better, produce results faster, and finish projects on budget.
  • Autodesk® FormIt® 360 Converter
  • Autodesk® Insight 360*
  • Global parameter enhancements
  • Improved software performance
  • Autodesk® Raytracer rendering engine
  • Text Editor and layout engine
  • Calculate in annotation tags
  • Dynamo graphical programming interface
  • Schedule improvements
BIM 360 Tools
BIM for owners delivers demonstrable value from design, through construction, and into operations. Bring predictability into the design and construction process, reduce building lifecycle costs, and better manage building portfolios.
Reduce waste in construction projects with tools that help contractors and subcontractors improve construction planning, produce results faster, and finish projects on budget to increase profit margins.
  • BIM 360 Glue
  • BIM 360 Docs
  • BIM 360 Field
  • BIM 360 Plan
  • Building Ops
Infrastructure Design Suite 2017
Improve Building Information Model (BIM) workflows with tools that help you improve project delivery, maintain more consistent data and processes, and respond faster to project changes. New and enhanced features in Infrastructure Design Suite 2017 civil engineering design software help you to:
  • Find better ways of collaborating
  • Associate and re-associate drawing objects to data shortcuts
  • Streamline time-consuming tasks
  • Enjoy improved performance and more flexibility
  • Improve workflows by enabling broader reuse of information
  • Import and Export AutoCAD Solids
Virtual Launch Event Details:
    Date: May 19, 2016 (Thursday)
    Time: 03.00 PM - 04.30 PM (IST)
    Hosts: Niranjan Kamath, Prasad Pandit, Preethi Rao
Click here for more details.
BIM for owners delivers demonstrable value from design, through construction, and into operations and helps contractors and subcontractors plan better, produce results faster, and finish projects on budget. It helps you to bring predictability into the design and construction process, reduce building lifecycle costs, reduce waste, and better manage building portfolios.
www.bim-3d-4d-5d.blogspot.com
www.bim-navisworks.blogspot.com
Twitter @SureshChotrani
Give KUDOs if happy & accept solution if post provides solution
Labels (1)
0 REPLIES 0
