General
Requesting a refund for an Autodesk product or service purchased from a reseller
Updated Education site for access to free software
3ds Max
Plug-in Assembly Load Error when launching 3ds Max
Problems with Backburner Manager and Server connections on cloned render nodes.
Alias
How to work with Autodesk Automotive Assets
AutoCAD
Certain dimensions in the drawing appear to be locked or not editable
Command preview not shown when drawing an ellipse in AutoCAD
Dynamic block attribute value displays incorrectly when first inserted into a drawing in AutoCAD
Error: “This page cannot be displayed” when using XPS Viewer to open DWFx files created in AutoCAD
Incorrect display of derived sketch in an exported AutoCAD DWG when a view contains a Break
Raster image transparency is not considered in polygonal viewport in AutoCAD
SWEEP command doesn’t work on some geometry in AutoCAD
Unable to see AutoDesk Vehicle Tracking 2015 tab in AutoCAD 2014
When you start the program it lists “You have ## days to establish an internet connection”
AutoCAD Civil 3D
Drawing units are metric but labels are displayed as feet
How to use GSB file for transformation of DHDN to ETRS
Pressure pipes catalog is empty, or no catalog database file in Civil 3D
AutoCAD Electrical
Multiple Bus with opposite direction
AutoCAD Map 3D
AutoCAD Map 3D 2016: Storm and Sanitary Analysis
AutoCAD MEP
Do MEP labels work on vertical section objects in AutoCAD MEP?
AutoCAD P&ID
AutoCAD P&ID: How to tag an offpage connector
AutoCAD Plant 3D
AutoCAD Plant 3D: Blind flange symbol is rotated in isometric drawing
AutoCAD Plant 3D: How to clear the recent projects list
AutoCAD Plant 3D: Show negative North and East coordinates rather than South and West coordinates in...
Bolt set calculation of WF valves in AutoCAD Plant 3D
Coordination model is clipped during pan and zoom
Documentation of isometric settings for AutoCAD Plant 3D
Ortho creation failed for several models which are selected together
Where is the list of the last opened projects saved for AutoCAD Plant 3D?
BIM 360 Field
BIM 360 FIeld_How to remove account admin using Account Admin Tools (HQ)
Link to Project Admin page in BIM 360 Field is unavailable
BIM 360 Glue
Autodesk BIM 360 Glue: iPad app crashes when opening merge model
BIM 360 Glue_Error message when launching application
CFD
Error: ‘Solver exited unexpectedly’ when using a distributed resistance region
Error: Unsupported file format in Creo 3 since installing CFD 2016
Flow is travelling in the reverse direction to what is expected
Which exceptions to add for performance in Symantec Endpoint Protection for CFD
Fusion 360
Data Panel does not function in Fusion 360
How to get support for CAM related questions for HSM Express, Inventor HSM, HSM Works or Fusion 360
Helius PFA
Helius PFA error 42 when running a simulation on Linux
Unsupported number of section points message when opening structural file in Helius PFA AME
InfraWorks
After the import of IMX data into InfraWorks the aerial images cover the coverages
How to import a point list into InfraWorks directly
Upload or download of models in InfraWorks 360 not possible
Inventor
Action Rule to empty properties after Copy Design does not work for Inventor files
Autodesk Vault 2016 Job Processor synchronized not Autodesk Inventor dwg files
Could not use capital letter as filename extension in iLogic
Graphics Issue in Inventor 2016 Drawing with AMD FirePro w8100
How to change deform options to ‘actual’
Inventor - Copy surface object is not adaptive.
Inventor 2016 exits on a Vault Job Processor machine when creating a DWF from a drawing IDW/DWG that...
Inventor crash during the deleting of a drawing view.
Inventor parameters do not update when using iLogic and Excel.
Inventor Spirals when drawn very small lose their precision.
Inventor: Emboss on large spherical surface fails with wrong geometry
Inventor: Small or thin objects not honored as visible in drawing view
Invisible objects when Viewport is set to Realistic
Unable to place components from Vault in Inventor using Inventor Search
Maya
Best settings for use of Viewport 2.0 for displaying textures in Maya
Cannot find procedure “mayaBatchRenderProcedure”
MotionBuilder
Removing Materials from MotionBuilder Scene
Nastran
Does adjusting the value of LNCONTACTITERTOL affect convergence in Nastran
Error E5004 ‘STIFFNESS MATRIX SINGULAR OR NON-POSITIVE DEFINITE’
Installing Autodesk Nastran with Autodesk Within
Nastran In-CAD
Navisworks
Auto Save Setting control in Navisworks
Navisworks: How to use Switchback with a Collaboration for Revit model
Revit
Assembled stair carriage and stringer support parameters are mixed up in Russian
Creating MSP out of EXE for Revit 2015 UR10
Exporting Revit families with SDNF-Export
Revit overwrites instance parameters when swapping families
Revit: How to find the Release 2 update for 2016 for Eflex customers
UK English Revit includes American terms for beams' Structural Usage property
Values for Top and Base are not displayed for balusters created in Revit in a different language
Robot Structural Analysis
MESHING ? What are the reasons of problems such as lack of mesh generation, incoherent meshes on edg...
ROBOT Analysis-How to include relative displacements of supports in seismic analysis of a building
Simulation Mechanical
How can the nodal rigid boundary constraint be selected in Simulation Mechanical
Vault
Content Indexing Error Exception: Value cannot be null.
Edit properties in Vault Office Thick Client
Error when applying Autodesk Vault 2016 SP1 - .NET is not installed
How Does Licencing Work in the “Paid For” versions of Vault?
Item view in files of Vault Thin Client
Not all browser names change with a Copy Design
Vault Client is crashing when downloading specific Inventor assembly
Vault Job Processor 2014 DWF error: “Retrieving the COM class factory”
When creating the preview for Autodesk Vault Explorer, the message appears: “Unknown error during pu...
Where can I download the Sharepoint installation files for Vault 2016?
Within
If you need any additional help, please visit us on Twitter @Autodeskhelp or if you have any other product specific questions please post a new message in one our Autodesk Community forums.
