Post Archive (Read Only)
New and Updated Solutions! Maya, Revit, Infraworks, and more!
1 REPLY 1
jessica.t
906 Views, 1 Reply
Installation and Licensing
Disabling Autodesk Application Manager on install
Setup.exe Entry Point not Found Litehtml.dll
3ds Max
3ds Max Backburner Error retrieving information An existing connection was forcible closed by the re...
How to change graphics display driver in 3ds Max
Starting 3ds Max gives error Unhandled exception has occurred in a component in your application
Advance Steel
Advance Steel: Cannot export to Navisworks
Advance Steel: Compound beams are not summarized by section in BOM list
Advance Steel: Handrailing problem - different results for similar situations
Advance Steel: How to change used material in table for unwinding
Advance Steel: How to get compass marks (orientation marks) for beams on GA drawings
Advance Steel: Wrong lines appear across plot
AutoCAD
A clipped Recap point cloud is not displayed correctly in AutoCAD or InfraWorks
AutoCAD dwg file cannot checked-in anymore into Autodesk Vault
Cursor disappears in viewport of drawing when LINEFADING is on
Custom Toolbar Icons show as a [?] question mark
How to plot / print from AutoCAD (AU 2014 class)
How to reset the CUIx in AutoCAD
Save Error: Could not draw text
Small text formatting toolbar for attributes
AutoCAD for Mac
Understanding AutoCAD for MAC plot settings
AutoCAD Civil 3D
“Remove Items” and “Add Items” command does not work on pipe network tables.
Add or Remove Features for Civil 3D 2015 shows an empty Content Selection Dialog
Civil 3D is freezing and not responding
Civil 3D: Can I combine Point Reports at the same time?
Crash when defining initial station point of a traverse
Elliptical pipe rotation
Spell Check is not possible in AutoCAD Civil 3D
The local import of a Civil 3D DWG does not work
The REB Export of the Civil 3D DACH Extension does not create a correct REB file
Traverse editor does not save last line in a closure
Unable to copy certain styles into a new drawing
AutoCAD Electrical
Locating symbols for 1763 Micrologix controllers
AutoCAD Map 3D
How to remove *.genx file from Administrator Custom Modules/Extensions
Industry Model Report Designer: change of decimal places in reports for number values
AutoCAD P&ID
How to copy the customized user profile for AutoCAD P&ID to another computer
How to send a complete project with an identical environment to another person in AutoCAD P&ID or Au...
AutoCAD Plant 3D
AutoCAD Plant 3D: Cannot add new tag format to Pipe Run Component
AutoCAD Plant 3D: How to create an Ortho view with a custom scale
German version: When selecting pipes and bends together, line number tag is not available in the pro...
How to configure the working folder for AutoCAD Plant 3D projects with Vault
Autodesk 360
A360 Cloud Rendering: Rendering a walkthrough created through Revit in the Cloud
Collaboration for Revit: Communicator Button not showing up in Ribbon
Collaboration for Revit: Error “Subscription ended” when trying to access projects using Collaborati...
Collabortation for Revit: Non-Revit file link with Collaboration for Revit
Understanding A360 roles, permissions, and project types
BIM 360 Field
For documents uploaded to BIM 360 Field project library, markup function and images unavailable
Infraworks
A shadow is created in a snapshot when ambient occlusion is turned on in InfraWorks
Autodesk InfraWorks 360 2015.3 and Autodesk InfraWorks 2015.3 close unexpectedly on startup
InfraWorks: What is the proper workflow to import Microstation DGN files?
The Undo functions do not work in an InfraWorks model
When adding a surface terrain in InfraWorks the triangulation is not coorect and looks different as ...
When importing polygon data as terrain InfraWorks connects the polygons and builds one surface
Inventor
“Table” node of Patterned iPart disappears on Replace operation
Adaptive part has wrong result while changing an assembly constraint
Adding extrusion on coil causes Inventor to fail physical properties calculations
Automatic feature selection in browser not working for migrated mirror features
Bad DWF files from Inventor 2013
Browser node not expandable in presentation environment
Components removed from an Inventor assembly continue to be linked
Export BIM - RFA, not possible with parameters
Publishing monochrome dwf from Autodesk Inventor idw-file
Retrieved dimension not using the same style
section view in weldment shows wrong dimension
Small sizes components not displayed in assembly drawing view containing large sizes components
Starting Inventor help brings error message [Error 31]
Thicken command fails on complex geometries
Values of dimensions attached to axis in drawing view don’t reflect model dimensions
When exporting the Autodesk Inventor idw file to Autodesk AutoCAD Inventor dwg file, the button opti...
Maya
Error: (Mayatomr.Output) : failed during mental ray rendering: mental ray abort
Installation and setup of Maya Web browser plug-in
mental ray error object: renderView cannot be found
nHair differences from Maya 2014 to 2015
Strange performance issues in Maya
Nastran
Error: “Fatal error S1053: File: %FILENAME% UNABLE TO OPEN, STATUS: 30” in Nastran
Nastran In-CAD
Can the normal of surface geometry be manually managed in Nastran In-CAD
How to sum applied forces in Nastran In-CAD
How to use Inventor weldment features in Nastran In-CAD
Navisworks
Decals are not visible in Navisworks
Recap
Photo upload limit on ReCap360
Recap displays an error message when trying to open a RCP file on Recap 360
Revit
Buttons in ribbon do not display properly in Windows 8.1 (Revit)
Color fills are missing in duct legends
How to manage CAD links with Revit Server.
Revit options for Remote Access
Revit: Rise/Drop symbols line weight does not match the pipe or duct when below another element
Revit: Some families are not cut in section view
When zooming in to a very high level imported dwg geometry may appear slightly offset
Simulation CFD
Convergence plot is updating very rarely during calculation
How to install the Simulation CFD plugin for Inventor Fusion
Simulation Mechanical
Error: “forrtl: severe (157): Program Exception” - access violation in Simulation Mechanical
How to show/hide results above or below certain values in Simulation Mechanical
Message: TODO: crack Alg_fea dailog return codes
Simulation Moldflow
Compression Molding simulation of Thermoplastics in Moldflow
Import of Catia V5 R24 files to Moldflow fails
List of file extensions used by Moldflow
Manually calculated Clamp Force is higher than simulated clamp force
Moldflow macro for flatness calculation
Simulation Moldflow Insight analysis sequences utilizing the GPU
Vault
Create new folder error: One or more of the entities
How to map properties in Vault
Login to Vault very slow
Vault error: “The following files could not be checked out due to vaulting restrictions”
If you need any help, please visit us on Twitter @Autodeskhelp or if you have any other product specific questions please post a new message in one our Autodesk Community forums.
Jessica Thrasher
Labels (1)
1 REPLY 1
in reply to: jessica.t
Some links no longer work.
Technology Administrators
