General
Citrix support for 2016 products
Turbulence Intensity within the model is producing values over 100, this seems wrong
What value of turbulence intensity should be applied?
Where to download the Autodesk Application Manager 5.0.142.5
Why is there an abnormally hot region within a model
Advance Steel
Advance Steel: How to move hand rail posts
Advance Steel: How to remove the part numbers from a model
Advance Steel: The default %Norm doesn’t work for the bolt label in a view detail
Where to download Graitec PowerPack for Autodesk Advance Steel 2016
AutoCAD
Cannot enter a command when crosshairs are on a grip
How to assign keyboard function keys to AutoCAD commands
How to do batch conversion of drawings using EXPORTTOAUTOCAD command
How to turn off Annotation scale icon in AutoCAD
How to update extracted data using AutoCAD 2016
Icons display in the AutoCAD status bar even though all icons are turned OFF
Linework appears faint or halftone in AutoCAD
Render does not complete in AutoCAD
Script Error and Security Alert when launching AutoCAD 2016 on Windows 10
Text is stretched when plotted using Drawing to PDF.pc3
The Windows Installer error appears, when installing the Service Pack or Hotfix
AutoCAD for Mac
Cannot change render background color in AutoCAD for Mac
AutoCAD Architecture
Column justification does not match Properties setting (AutoCAD Architecture)
Nothing is inserted when trying to insert a Detail Component in AutoCAD Archtiecture
AutoCAD Civil 3D
Can Pressure Pipes export to LandXML format
FDO coonection to a shape file only displays the data table but no geometry
Geotechnical Module Database Backup
Intersection “Maximum Grade Change”
AutoCAD Electrical
In AutoCAD Electrical, unwired terminals cannot be removed from Terminal Strip Editor
AutoCAD Mechanical
How to enable the dialog window for the AMCHAM2D command in AutoCAD Mechanical
AutoCAD MEP
How to create a live section that cuts both Solids and AEC Objects in AutoCAD MEP
AutoCAD P&ID
AutoCAD Plant 3D
AutoCAD Plant 3D: How to show the insulation for a component of the type MISC-COMPONENT in an isomet...
Change the authentication type for SQL Server projects
Dynamic input not available during insertion of inline assets in AutoCAD Plant 3D 2016
Standard equipment templates will be overwritten by user-defined equipment templates
BIM 360 Glue
BIM 360 Glue Viewer does not install
CFD
Interface crashes with an error report window when the model is opened
Is it possible to model evaporation or a liquid?
Entertainment Creation Suite
How to include mental ray service pack when using the Entertainment Creation Suite 2015 installer
Helius PFA
What is the path progression for Helius PFA when calling materials
What material system is XAS_913C referenced by Helius PFA
What resources are available related to cohesive simulation with Helius PFA
InfraWorks
InfraWorks opening file dialog causes crash
Performance issues with regeneration in InfraWorks
Inventor
Components containing assembly features disappear after updating AnyCAD reference in Inventor
Content Center standard parts fail with error on Refresh
In Inventor 2016 the Ctrl+Tab does not work correctly with 3 or more documents open
Inventor 2016 is not importing Custom iProperties from Standard.ipt when importing a STEP file
Inventor: Cannot delete ribbon cable and crash when editing this cable
Performance issue while deleting drawing dimensions
Standalone Design Assistant closes when hitting ESC
Moldflow
How Moldflow handles material sticking to the wall in terms of the warp calculation
Nastran In-CAD
Nastran In-CAD analysis contains parts that were disabled in Solidworks
Slow performance after meshing model in Nastran In-CAD 2016
Recap
Import and Export of notes from and to CSV in Recap
Revit
Area of door is incorrect after exporting model to IFC from Revit
Collaboration for Revit: Publish fails
Error: “The request could not be satisfied” when clicking Sub Center options
New browsers not supporting Silverlight for Revit Server Administrator
Pressure Drop value doesn’t seem to work on dampers in Revit 2015/ 2016
Revit: Feature Request - Adding Parameters to Materials
Simulation Mechanical
Convergence issues with contact and bolt preload in Simulation Mechanical
Fatigue Analysis - Run-time error ‘76’ Path not found error in Simulation Mechanical
How to apply centrifugal loads in Simulation Mechanical
Vault
Can Autodesk Support generate Microsoft SQL queries to be run on Vault databases?
Job Processor scheduled to restart
Notification when the Jo Processor is not working
