General Topic/Installation & Licensing
2017: Cascading sequences for Autodesk products
2017: FLEXnet feature codes for Autodesk products
Autodesk Network License Service not starting on the 2017 version 11.13
What is the Autodesk License Service (x64) in my Control Panel?
You want to know how to install a network licensed version of 2017 software
3ds Max
3ds Max - Rendering warning from Maya CAD imported Model
3ds Max - Quicksilver not rendering animated PathDeform objects
Advance Steel
External BOM list error - Some parts appear several times when using a customized BOM template
How the existing tabular data / Library records are used by a joint
Model check function giving errors about beam body when the joint “Shear plate” is used
How to map channel sections in Advance Steel 2016
How to modify an attribute for a barcode in a drawing in Advance Steel 2016
How to replace beams with plates in the Turnbuckle gusset bracing joint in Advance Steel 2016
What is the License Manager Option
Alias
Autodesk Alias 2016 will not start up properly on OSX10.11.x (El Capitan)
AutoCAD
AutoCAD 2016: Plotting to HP plotter on Windows 10
AutoCAD 360 Pro Mobile App Free with AutoCAD Subscription
AutoCAD is not included in Autodesk Product Design Suite Ultimate
ED command alias does not work in AutoCAD 2015
Get Up to Speed with AutoCAD 2017
How to change the location for images saved from an imported PDF in AutoCAD 2017
How to snap to gap in dotted linetype
Line smoothing doesn’t stay turned off from session to session
Location of acad.pgp file in AutoCAD
Osnaps don’t work on 3D objects in blocks in AutoCAD
SHX files not included in PDF import
You want to know how to borrow a network license in your 2017 software
You want to know how to change or reset your licensing on your 2017 software
You want to know how to create a Deployment of 2017 software
You want to know how to install a single instance of 2017 software
AutoCAD Civil 3D
Alignment Stations projected to adjacent alignment
Cannot snap to corridor model when referenced
Civil 3D: Intersection Wizard produces fatal error
How to connect to a XLS database in Map 3D or Civil 3D
How to display the cut length of Pressure Pipe
Is using feature lines for grading the only way to grade?
Surface data exchange InfraWork Civil 3D
AutoCAD Electrical
Panel BOM report is missing the description of certain components
AutoCAD for Mac
How to create Multilinestyle in AutoCAD for Mac
Missing objects in a PDF created in AutoCAD for Mac
Trouble attaching xref drawings in AutoCAD for Mac
AutoCAD Map 3D
AutoCAD Map 3D typical workspace environments are missing
AutoCAD Map 3D: FDO objects with solid filling seem to have a transparent style
Georeferenced Tiff file will not load into AutoCAD Map 3D
AutoCAD Mechanical
Mechanical: Change tolerance precision shown in fits list
Power view does not inherit the layer properties from last view
AutoCAD Plant 3D
AutoCAD Plant 3D: Connection failed because of a property conflict
AutoCAD Plant 3D: Objects not displayed correctly when using the Realistic visual style
Wrong angle of isometric symbol for a rotated actuator
AutoCAD LT
Get Up to Speed with AutoCAD LT 2017
BIM 360 Field
How to add a new Account Admin within the BIM 360 Account Admin Tool (HQ)
Some photo images are missing within the Photos area of my BIM 360 Field project on the iPad
CFD
Discontinuation of Autodesk CFD CAD Connections for NX, Parasolid and Pro/ENGINEER
Heat sink material does not have any heatflow through the base surface in Simulation CFD
Moist Air mixing material model difusses instantly in Simulation CFD 2016
Fusion 360
Adjusting Windows 10 display scaling settings for Fusion 360
Fusion 360 user interface menus don’t work on a Windows MSI GT72S Computer
Tutorial will not exit and no option to close on iMac
How to create a 2D drawing from your CAD file in Fusion 360
Incorrect System time warning when starting an Autodesk 360 application
Inventor
‘Failed to acquire a license’ during login of Content Center in Inventor
A gap between a text and a leader line is not changed by Dimension Style > Display > C: Gap
Adjusting the width of commands on Quick Access Toolbar
Connected Design does not load properly - Error 404 or 403 is shown
IDW view does not have the same colors as the IPN file for parts
Inventor Crashing - Graphics related issue
Inventor drawing browser name cannot set back the file name automatically
Unable to create /save iLogic code for external rule
Maya
Mental Ray plugin for Maya 2016 on Mac not in plug-in manager
When you start Maya LT 2017 or Stingray on a MAC OS you are unable to login
When you start Maya LT or Stingray 2017 on a MAC OS, the product hangs on start
When you start your 2017 product you display an error referencing a “clock” problem
Where are the Dynamics menu items such as nCloth, nParticles, and nConstraints in 2016?
You are unable to access Maya LT 2017 or Stingray in a proxy environment using PAC files
You receive a MAC “Keychain” error when you start Maya LT or Stingray on MAC
You want to know how about Proxy-Auto-Configuration (PAC) files for 2017 licensing
Moldflow
Variable Cloud Credit Consumption for Design of Experiments in Autodesk Moldflow Insight
Nastran
Is solid element relative stress error output from Autodesk Nastran accurate
Thermal conductance input is not available in FEMAP for Autodesk Nastran
ReCap
System requirements for Autodesk ReCap 360 2017
Revit
Certain Revit elements are half-toned within a particular view
Exported DWG file from Revit is not showing properly
How to check Collaboration for Revit status
Revit Error: Cannot load non-shared version of Revit family
Revit freeze when modifying schedule parameter
The dwg export result and print result are incorrect
Wrong angle of elevation/sections after Rotate Project North
Robot Structural Analysis
Strange patches or strips on maps
Simulation Mechanical
Analysis fails when running from a network drive in Simulation Mechanical 2016
Vault
Autodesk Vault Cloud Support for HP VPC
Automatic Prompt when opening file from Vault does not appear
Cannot install MS Office Add-In for Vault Pro 2015
Error: Invalid URL the hostname could not be parsed during Vault Login
Support of MS Office 2016 in Vault
Vault Office 2016 thick client crash while renaming a search folder
Additional Topics
Fluid or air flow is near zero, very low velocities
Triple switch as input to ShaderFX doesn’t work
If you need any additional help, please visit us on Twitter @Autodeskhelp or if you have any other product specific questions please post a new message in one our Autodesk Community forums.
