Autodesk Formit 360 User Interface Using
SerdarHakann
Advisor Advisor
Message 1 of 1
SerdarHakann
First of all, what is the answer to the question formit Formit 360 360 both tablet and desktop computer or laptop, you can use a 3-d visualization software.
Formit to a very particular architectural area Formit 3D studies and can render. The program is quite simple to use interface and web-based because it is a software that works with your work that you have made to your account record and A360 everywhere.
Now if you wish, Formit 360 's interface features let's look briefly;
As you can see, this is the way the input section Formit 360 A360 login with your account as of the province, and we opened the session after the Formit 360 is opening itself automatically;
Formit 360 's interface is quite simple, as you see in the picture has a look and the above list is pretty easy.
Located in the upper left corner and contact details in the field selected in red when you click on the options, you can create new work with dostası, you can open, work file, you can export and import your work in different records can perform and you can access your account A360.
Indicated by the red box in the commands you scene with all shapes and you want to measure, you can create objects and objects in or they can perform 2D illustration. In addition, you can modify the values of your stage lighting
Right-click the menu commands, you can have all the controls related to the stage.
Serdar Hakan DÜZGÖREN
Autodesk Expert Elite
Forumlarımızda çözülen sorularınızı "ÇÖZÜM OLARAK KABUL ET" seçimiyle işaretlemeyi lütfen unutmayın.
Beğendiğiniz mesajları lütfen "Övgü Puanı" ile ödüllendirin.
3D Generalist |Serdar Hakan.NET | Serdar Hakan AKADEMİ Türkiyenin Online Eğitim Akademisi |
serdarhakanakademi
Replies (0)
