Simple Tutorial for Point Layout
chris
Message 1 of 8
chris
Is there a simple tutorial for Point layout available alternatively is there a FAQ page that answers most initial questions
Replies (7)
Message 2 of 8
s.hamel
Chris, under the start menu -> Autodesk ->Autodesk point Layout 2018 folder you will find a Autodesk Point Layout Preview Guide.pdf which should help you get started.  It covers use within AutoCAD, Revit, and Navisworks.  After review if you have follow up questions, feel free to post them here.
Shayne Hamel
Manager, Principal Software Engineering
Message 3 of 8
chris
Thanks found it
Message 4 of 8
chris
Hi
When I wish to compare layout points with staked out survey points the report displays differences in inches
Is there a way to display the differences in metric values
Message 5 of 8
s.hamel
Depends on design product in use:
Revit:  There is a checkbox shown, Use Project formatting, which will match your project settings, otherwise it will use decimal feet.
AutoCAD: Displays based on document units, style changes though, Decimal for metric, Architectural for imperial.
Navisworks: based on overall documents Units
Shayne Hamel
Message 6 of 8
chris
thanks - used measurement command and set to 1
Message 7 of 8
I would like to view the manual on an iPad to determine if the software is suitable for purchase. Is there anyway that the PDF file can be made available without downloading the free trial? We are in the process of possibly shifting all our software from Bentley to Autodesk ,but this may not occur if I can’t find a suitable replacement for Bentley’s Geopak.
Michael
Message 8 of 8
s.hamel
Here is a link to the preview guide.  I cannot talk to comparison with Geopak since I do not know that software, but you may also want to take a look at BIM 360 Layout information was well.
Shayne Hamel
