Scheduling Nested Points
v_yang84
v_yang84
Is there a way to schedule nested points?
I need to schedule them to be able to order sleeves and I am having to manually number them after they are already automatically numbered through APL. This is time consuming and have tried to figure out a away to pull the info needed to no success. I have noticed that once you nest them, they come up as GTP points versus just Pointnumber, Pointrole, etc...
s.hamel
Not sure I understand why you are needing to manually #, perhaps your schedule is actually including the parent family?
Here is a quick and dirty schedule creation steps, check if you are doing something different.
Create new Multi-Category Schedule
Add PointNumber and PointDescription fields
Edit Filter to include (FilterBy: PointNumber -> Parameter Exists)
Edit Sorting/grouping to include Grand Totals: Count and totals
List and count at bottom of it should match what you see on the Manage Point screen after hitting Apply with no filters.
Shayne Hamel
Manager, Principal Software Engineering
v_yang84
I do not have those fields to choose from. Also, will those pull from the nested points that have changed to what I have attached that is showing them under GTP_PointNumber?
My process is that I am using APL to autonumber which gives me the number shown in GTP_PointNumber but I can't find it to schedule it. I have tried making a parameter but I am not skilled in that to figure it out so my workaround is plugging in the point number into the "Mark" field so I can schedule based off of that field. I have a high rise to do with roughly 200 points per floor and it's time consuming.
I have made other parameters to be able to show up in the schedule but I can't figure this one out.
s.hamel
Yes, those values will feed from the host family directly to the PointNumber field of the actual point instance, you should basically ignore the GTP_ ones completely.  Are you sure you are doing a Multi-Category schedule?  If not those fields most likely wont be available.  Generic Model Schedule also works.
Shayne Hamel
v_yang84
Got it!
I read and followed more carefully and what you said works.
Thank you SIR!
