I was using the tagging command, add tags and asked it to tag all some of the electrical points got tags and some did not. I was wondering what might be wrong?
Prateek
Prateek
Solved by zach.crumal. Go to Solution.
Hello Prateek, is this something that you can reproduce in a small Revit project and post up? Not something I have seen before so would really need to look at a sample to provide any insight.
If this is in Revit make sure in the 2D plan view that the view range is fully adjusted to show the entire point and retry tagging.
Thank you, that was the problem. The view range was not capturing all the points.
