Is this correct?
procedure.
1. I link the cad file on revit then align the cad file with the revit.
2. clock the coordinates (point layout) and key in the coordinate points
given to me and named it 50-1002 coordinates.
3. create control points 4ft from the grid lines I can use.
4. then made points for my conduits.
5.Then exporting- i use the E,N,Z (XYZ) for point exporter, decimal feet,
export dwg, site coordinate system( 50-1002 coordinates i made) and click
export.
6. Once I click export dwg.-which one to use for the export profile (APL
DEFAULT, PROJECT INTERNAL, SHARED?)
7.coordinate system- use Project or shared coordinate for exported DWG?
I used the APL DEFAULT AND PROJECT COORDINATE and the DWG file is just on a
regular XYZ layout, does it matter or should it show the right angle
supposed to be when exported. But the control points 50 and 10002 that I
made just to duplicate the coordinates 50 and 10002 seemed to be the same
numbers (coordinates) that were given.
Will the orientation of the exported cad matter on site? or as long the
point is correct it should be fine?
