help help how to use autodesck point layout for revit
hello everybody
 i am want to use point layout for revit but i am newbie. where should i start ?
s.hamel
Hello and welcome to the forum.  Best place to start would be with the User guide.  While it is a bit outdated and won't cover some of the more advanced options, all the concepts are still valid and basics are covered.  From the Autodesk point Layout ribbon, the very last section is Help, and the User Guide can be launched from there and it will outline the main functions to use.
After reviewing those, start by dropping some manual points, then some control points, finally trying one of the automated functions such as marking all your walls, and then exporting those out to a file.
Additionally if you search Youtube you will find a lot of videos highlighting specific workflows.
Shayne Hamel
Manager, Principal Software Engineering
thanks you for reply.
now i am use bim 360 layout for androi tablet but  i am can not import point ( csv file )
what should i do.
s.hamel
Is it giving you an error when you try to import the csv?  If you want to attach or message me the csv Ill take a look.
Shayne Hamel
