Adding points to BOTTOM of pipe in Revit
bhorningZP8TX
bhorningZP8TX
I am trying to add points to the BOTTOM of a pipe. Despite checking the box 'Bottom/End' under 'Marking Style' I still get points at the center of the pipe. Any advice or help with this?
s.hamel
Bhorning, those marking style values are actually meant to indicate top/bottom for vertical pipe, or Start/End for horizontal, not whether the point is placed offset based on the diameter.  What you are describing is unfortunately not an option currently when marking pipe.
Shayne Hamel
Manager, Principal Software Engineering
