2018/3/5:14:53:21 Сергей DESKTOP-M3E5VAK === Setup started on DESKTOP-M3E5VAK by Сергей ===
2018/3/5:14:53:21 Сергей DESKTOP-M3E5VAK Path_Length: 128
2018/3/5:14:53:21 Сергей DESKTOP-M3E5VAK Current Directory C:\Users\D899~1\AppData\Local\Temp\_AIB172.tmp
2018/3/5:14:53:21 Сергей DESKTOP-M3E5VAK Launch
2018/3/5:14:53:21 Сергей DESKTOP-M3E5VAK Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomPlatformCheck CB_SOURCE=C:\Users\D899~1\AppData\Local\Temp\_AIB172.tmp\Setup\AcSetup.dll
2018/3/5:14:53:21 Сергей DESKTOP-M3E5VAK Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2018/3/5:14:53:29 Сергей DESKTOP-M3E5VAK PageOpen LaunchDialog
2018/3/5:14:53:39 Сергей DESKTOP-M3E5VAK PageOpen LicenseDialog
2018/3/5:14:53:42 Сергей DESKTOP-M3E5VAK PageOpen ProductSelectionDialog2
2018/3/5:14:53:50 Сергей DESKTOP-M3E5VAK PageOpen FullProgressDialog
2018/3/5:14:53:50 Сергей DESKTOP-M3E5VAK Installing Universal C Runtime (KB3118401): "C:\Autodesk\DWGTrueView_2017_Enu_64bit\3rdParty\ucrt\AdUcrtInstaller.exe" /S
2018/3/5:14:53:51 Сергей DESKTOP-M3E5VAK Install Universal C Runtime (KB3118401) Succeeded
2018/3/5:14:53:51 Сергей DESKTOP-M3E5VAK Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\DWGTrueView_2017_Enu_64bit\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\D899~1\AppData\Local\Temp\vcredist_x86_2015.log
2018/3/5:14:53:53 Сергей DESKTOP-M3E5VAK Install Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1603
2018/3/5:14:53:53 Сергей DESKTOP-M3E5VAK Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\DWGTrueView_2017_Enu_64bit\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\D899~1\AppData\Local\Temp\vcredist_x64_2015.log
2018/3/5:14:53:54 Сергей DESKTOP-M3E5VAK Install Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1603
2018/3/5:14:53:54 Сергей DESKTOP-M3E5VAK Installing DirectX Runtime: "C:\Autodesk\DWGTrueView_2017_Enu_64bit\3rdParty\DirectX\DXSETUP.exe" /silent
2018/3/5:14:54:09 Сергей DESKTOP-M3E5VAK Install DirectX Runtime Succeeded
2018/3/5:14:54:10 Сергей DESKTOP-M3E5VAK Installing Autodesk® DWG TrueView™ 2017 - English: TRANSFORMS="C:\Users\D899~1\AppData\Local\Temp\_AIB172.tmp\x64\dwgviewr\dwgviewr-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\DWGTrueView_2017_Enu_64bit\" INSTALLDIR="C:\Program Files\Autodesk\DWG TrueView 2017 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2018/3/5:14:54:10 Сергей DESKTOP-M3E5VAK Install Autodesk® DWG TrueView™ 2017 - English Failed Installation aborted, Result=1603
2018/3/5:14:54:10 Сергей DESKTOP-M3E5VAK Rollback DirectX Runtime Failed Failure is ignored, Result=1603
Решено! Перейти к решению.
Решено: Alexander.Rivilis. Перейти к решению.
Код ошибки 1603 достаточно сложно диагностировать. Причин может быть множество. В любом случае:
1. Выполняйте иснталляцию с правами Администратора и при отключенном контроле учетных записей (UAC).
2. Очистите каталог %TEMP% перед инсталляцией.
3. Почитайте эту тему: https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Не нашли то, что искали? Задайте вопросы в сообществе или поделитесь своими знаниями.
