Добрый день.
Ошибка при установке 3 ds Max 2018 для учащегося.
Ниже лог, помогите разобраться в проблеме.
Launch
CommandLine /PK 128J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/Autodesk...
=== Setup ended ===
Launch
Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{2335B6B...
Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{2335B6B...
PageOpen LaunchDialog
PageOpen LicenseDialog
PageOpen ProductInfoDialog
PageOpen ProductSelectionDialog2
PageOpen FullProgressDialog
Download Play STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{2335B6B...
Download Complete STARTMARKER http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{2335B6B...
Download Skipped VCREDIST2012X86 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{2335B6B...
Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x86\VCRedist\2012UPD4\vcredist_x86.exe" /install /quiet /norestart
Microsoft Visual C++ 2012 Redistributable (x86) return code: 0
Install Microsoft Visual C++ 2012 Redistributable (x86) Succeeded
Download Skipped VCREDIST2012X64 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{2335B6B...
Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x64\VCRedist\2012UPD4\vcredist_x64.exe" /install /quiet /norestart
Microsoft Visual C++ 2012 Redistributable (x64) return code: 0
Install Microsoft Visual C++ 2012 Redistributable (x64) Succeeded
Download Skipped VCREDIST2013X86 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{2335B6B...
Installing Microsoft Visual C++ 2013 Redistributable (x86): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x86\VCRedist\2013\vcredist_x86.exe" /q /norestart /l C:\Users\6145~1\AppData\Local\Temp\vcredist_x86_2013.log
Microsoft Visual C++ 2013 Redistributable (x86) return code: 0
Install Microsoft Visual C++ 2013 Redistributable (x86) Succeeded
Download Skipped VCREDIST2013X64 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{2335B6B...
Installing Microsoft Visual C++ 2013 Redistributable (x64): "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\x64\VCRedist\2013\vcredist_x64.exe" /q /norestart /l C:\Users\6145~1\AppData\Local\Temp\vcredist_x64_2013.log
Microsoft Visual C++ 2013 Redistributable (x64) return code: 0
Install Microsoft Visual C++ 2013 Redistributable (x64) Succeeded
Download Skipped DOTNET46 http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/{2335B6B...
Installing .NET Framework Runtime 4.6: "C:\Autodesk\WI\Autodesk 3ds Max 2018\3rdParty\NET\46\wcu\dotNetFramework\dotnetfx46_full_x86_x64.exe" /q /norestart
.NET Framework Runtime 4.6 return code: 5100
Install .NET Framework Runtime 4.6 Failed Installation aborted, Result=1603
Rollback Microsoft Visual C++ 2013 Redistributable (x64) Failed Installation aborted, Result=1619
Rollback Microsoft Visual C++ 2013 Redistributable (x86) Failed Installation aborted, Result=1619
Rollback Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1619
Rollback Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1619
PageOpen InstallCompleteDialog
=== Setup ended ===
Launch
CommandLine /PK 128J1 /SN xxx-xxxxxxxx /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET18SWDLD/2018/3DSMAX/2DD64FCB-CEA0-4A63-9D30-2C31C1E56F6C/WI/Autodesk...
=== Setup ended ===
=== Setup started on ELENAPC by Елена ===
Launch
Solved by Alexander.Rivilis. Go to Solution.
@Anonymous
Приветствую на форуме. Выполните эти рекомендации: Рекомендуемые действия при установке ПО Autodesk
Если будут ошибки при установке выкладывайте сюда все log-файлы.
Кроме того похоже потребуется переустановка .NET Framework 4.6: https://knowledge.autodesk.com/ru/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/RUS/How-to-remove-and-reinstall-the-Microsoft-NET-Framework.html
Facebook | Twitter | LinkedIn
Спасибо, переустановила NET 4.6 (правда пришлось помучиться, не хотел ставиться) и теперь все ОК.
