If you don't work for several months at a time, then the rental-model license would seem to be ideal for you. The smallest increment is one month, which is reasonable. Short of cloud-hosted software I doubt you'll find hourly charge-out rates for licensed software. If you have about a month of work then you get the one month license; if you land something significant then a quarterly license may be more appropriate. With a fixed term available you can cast around for other work that can be fit into that timeframe. With intermittent work the rental model costs are in-line (or better, if less work is involved) with the return on a perpetual license with a much higher initial cost.
As for work thats measured in the hours (as opposed to weeks) you would probably be better off with one of the free non-AutoDesk clones. If you are tied to AutoDesk products ie a vertical such as ACA or a third-party utility, then your client charge-back will need to be adjusted to reflect current expenses - just like the rest of us.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
