ObjectARX
Using sqlite3 to operate the database test.db
9 REPLIES 9
Message 1 of 10
463017170
789 Views, 9 Replies
test.pngUsing sqlite3 to operate the database test.db
Can you help me see how to create, add, and modify a database? Thank you!
9 REPLIES 9
Message 2 of 10
daniel_cadext
in reply to: 463017170
Maybe have a look at this project for inspiration
https://www.theswamp.org/index.php?topic=28286.0
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 3 of 10
463017170
in reply to: daniel_cadext
Thank you for your reply! I think it should be an ARX syntax issue?
Message 4 of 10
tbrammer
Unless I can't read the (chinese?) error messages I assume that the linker complaints about unresolved externals, right? Due to "std::basic_string<char...>" I suspect that this might be an UNICODE/ANSI issue.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 5 of 10
463017170
in reply to: tbrammer
Can you help me take a look at my code? Thank you very much!
Message 6 of 10
daniel_cadext
The best way to approach this is to download the SQLite Amalgamation
https://sqlite.org/download.html
Setup your solution with two projects.
Compile the SQLite Amalgamation as a static library
Static link to the new library from your ARX project.
This way you won’t have any DLLs to load.
Message 7 of 10
daniel_cadext
Here's an old project that should better illustrate, it's an old version of SQLite, you can probably just drop in the new Amalgamation
Message 8 of 10
463017170
Thank you very much for your reply! Lisp is not familiar with it.
Message 9 of 10
daniel_cadext
The lisp is not required, but you can see how to use it from C++
Message 10 of 10
463017170
Can you help me modify test.rar?
AutoCAD Inside the Factory
