because AutoCAD OEM does not provide direct access to its ActiveX object model from outside its process I
need to create a COM wrapper to expose those interfaces you will need to access outside AutoCAD OEM process. I need to expose a function that use a custom command a call it from VBA app.
I try to use this project https://forums.autodesk.com/t5/objectarx/unable-to-zoom-particular-enitity-in-autocad-oem/td-p/95204... but without success.
Can someone describe to me the step-by-step procedure for how to create the project or use an existing example? Thank you,
Bruno
