If my ARX is loaded I can draw some of my AcDbPolyline-derived custom objects save and reload with no (apparent) issues. However, if I load the saved file without the ARX (to check the proxies work) the file is somehow bad. AUDIT tells me things like this:
Command: AUDIT Fix any errors detected? [Yes/No] <N>: n Auditing Header Auditing Tables Auditing Entities Pass 1 Pass 1 200 objects audited Auditing Entities Pass 2 Pass 2 200 objects auditedAcDbZombieEntity(2E8) Extension dictionary AcDbLinetypeTableRecord: "TYPE1" Wrong type Removed AcDbZombieEntity(2E8) Invalid layer eNullObjectId $AUDIT-BAD-LAYER AcDbZombieEntity(2E8) was not repaired. AcDbZombieEntity(2EB) Extension dictionary AcDbLinetypeTableRecord: "TYPE1" Wrong type Removed AcDbZombieEntity(2EB) Invalid layer eNullObjectId $AUDIT-BAD-LAYER AcDbZombieEntity(2EB) was not repaired. Auditing Blocks 2 Blocks audited Auditing AcDsRecords Total errors found 4 fixed 0 Erased 0 objects
Any ideas what would cause this bad layer ID? Its specific to one of my objects types - other similar types don't have this issue. The layer the objects are supposed to be on exists.
