Proxy Object Problems
Kyudos
Advisor Advisor
Kyudos
If my ARX is loaded I can draw some of my AcDbPolyline-derived custom objects save and reload with no (apparent) issues. However, if I load the saved file without the ARX (to check the proxies work) the file is somehow bad. AUDIT tells me things like this:
Command: AUDIT
Fix any errors detected? [Yes/No] <N>: n
Auditing Header
Auditing Tables
Auditing Entities Pass 1
Pass 1 200     objects audited
Auditing Entities Pass 2
Pass 2 200     objects auditedAcDbZombieEntity(2E8)
Extension dictionary AcDbLinetypeTableRecord: "TYPE1" Wrong type            Removed
                    Invalid layer eNullObjectId         $AUDIT-BAD-LAYER
AcDbZombieEntity(2E8)             was not repaired.
AcDbZombieEntity(2EB)
AcDbZombieEntity(2EB)             was not repaired.
Auditing Blocks
 2       Blocks audited
Auditing AcDsRecords
Total errors found 4 fixed 0
Erased 0 objects
Any ideas what would cause this bad layer ID? Its specific to one of my objects types - other similar types don't have this issue. The layer the objects are supposed to be on exists.
tbrammer
Can you please append the DWG that causes the audit errors?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Kyudos
Problem file attached.
Virupaksha_aithal
Autodesk Support
Autodesk Support
Are you storing “acdblinetypetablerecord” in extension dictionary? The message is prompting that it is removing the object as acdblinetypetablerecord from extension dictionary. I feel acdblinetypetablerecord to be added to symbol table (AcDbLinetypeTable).
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Kyudos
I'm not consciously doing that - I am loading some line types from a .lin file. Does that put them in an extension dictionary?
tbrammer
It is even more strange:
The extension dictionary of the proxy entity with handle "2D8" is an AcDbLinetypeTableRecord.
But it should be an AcDbDictionary!
Here is a screenshot from ArxDbg.arx after command SNOOPDB and selecting entity 2D8:
Kyudos
I fixed this by changing the order of things in my dwg in/out functions to make sure I was doing the base class(es) first.
