ObjectARX
ObjectARX for AutoCAD 2013?
12 REPLIES 12
Message 1 of 13
jtm2020hyo
1064 Views, 12 Replies
where can I download ObjectARX for AutoCAD 2013?
12 REPLIES 12
Message 2 of 13
http://download.autodesk.com/esd/objectarx/2013/ObjectARX_2013_Win_64_and_32Bit.exe
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 13
I did not find the "Interop.ACSMCOMPONENTS19Lib.dll" reference.
where can I download "Interop.ACSMCOMPONENTS19Lib.dll"?
Message 4 of 13
@jtm2020hyo
You have to create this file with next command:
tlbimp acsmcomponents19.tlb /out:Interop.ACSMCOMPONENTS19Lib.dll  /namespace:AcSm  /machine:x64
Explanation: https://adndevblog.typepad.com/autocad/2012/05/resolving-references-when-using-tlbimp-.html
Expert Elite Member
Message 5 of 13
Check this attached file.
Expert Elite Member
Message 6 of 13
@jtm2020hyo
Do this work for Autocad 2020 and VISUAL BASIC 2019?
I need to recycle this 2013 code :
 * SheetSetTools. © Andrey Bushman, 2013
 * AutoCAD 2014 x64 Enu
 * COMMANDS:
 * SS-RENUMBER-ALL - Update the numeration for all sheets in the all opened sheet sets:
 * numbering of each subgroup shall begin with 1.
 * SS-RENUMBER-ALL-BASES-OF-FIRST - Update the numeration: to continue numbering on the
 * basis of the first element in the each subset (in the all opened sheet sets).
 * AutoCAD references:
 * AcCoreMgd.dll
 * AcDbMgd.dll
 * AcMgd.dll
 * Interop.ACSMCOMPONENTS19Lib.dll
using System;
using cad = Autodesk.AutoCAD.ApplicationServices.Application;
using App = Autodesk.AutoCAD.ApplicationServices;
using Db = Autodesk.AutoCAD.DatabaseServices;
using Ed = Autodesk.AutoCAD.EditorInput;
using Rtm = Autodesk.AutoCAD.Runtime;
using Comp = ACSMCOMPONENTS19Lib;
[assembly: Rtm.ExtensionApplication(typeof(Bushman.AutoCAD.SheetSetTools.SheetSetCommands))]
[assembly: Rtm.CommandClass(typeof(Bushman.AutoCAD.SheetSetTools.SheetSetCommands))]
namespace Bushman.AutoCAD.SheetSetTools {
    public class SheetSetCommands : Rtm.IExtensionApplication {
        const String ns = "bush"; // namespace
        /// <summary>
        /// Update the numeration for all sheets in the all opened sheet sets: numbering of
        /// each subgroup shall begin with 1.
        /// </summary>
        [Rtm.CommandMethod(ns, "ss-renumber-all", Rtm.CommandFlags.Modal)]
        public void Renumber_All() {
            Renumber();
        /// <summary>
        /// Update the numeration: to continue numbering on the basis of the first element
        /// in the each subset (in the all opened sheet sets).
        /// </summary>
        [Rtm.CommandMethod(ns, "ss-renumber-all-bases-of-first", Rtm.CommandFlags.Modal)]
        public void Renumber_all_bases_of_first() {
            Renumber(true);
        /// <summary>
        /// To update numbering of all sheets in the all opened sheet sets.
        /// </summary>
        /// <param name="continue_numbering">True - to continue numbering on the basis
        /// of the first element in the each subset (in the all opened sheet sets);
        /// False - Numbering of each subgroup shall begin with 1 (in the all opened
        /// sheet sets).</param>
        void Renumber(Boolean continue_numbering = false) {
            App.Document doc = cad.DocumentManager.MdiActiveDocument;
            Db.Database db = doc.Database;
            Ed.Editor ed = doc.Editor;
            Comp.AcSmSheetSetMgr mng = new Comp.AcSmSheetSetMgr();
            Comp.IAcSmEnumDatabase enumerator = mng.GetDatabaseEnumerator();
            enumerator.Reset();
            Comp.AcSmDatabase smDb = null;
            while ((smDb = enumerator.Next()) != null) {
                smDb.LockDb(db);
                String fname = smDb.GetFileName();
                Comp.AcSmSheetSet sheetset = smDb.GetSheetSet();
                String name = sheetset.GetName();
                String descr = sheetset.GetDesc();
                ed.WriteMessage("\nSheet Set name: {0}\n", name);
                Int32 ren_count = 0; // count of renamed sheets.
                Comp.IAcSmEnumComponent encomp = sheetset.GetSheetEnumerator();
                encomp.Reset();
                Comp.IAcSmComponent component = null;
                while ((component = encomp.Next()) != null) {
                    ProcessElement(ed, component, ref ren_count, continue_numbering);
                encomp.Reset();
                smDb.UnlockDb(db, true);
                ed.WriteMessage("Renumbered sheets count: {0}\n", ren_count);
            enumerator.Reset();
        /// <summary>
        ///  Recursive processing of the elements: change the sheet's number.
        /// </summary>
        /// <param name="ed">An Editor for the output.</param>
        /// <param name="component">Component of Sheet Set.</param>
        /// <param name="ren_count">The count of renumbered sheets in the sheet set.</param>
        void ProcessElement(Ed.Editor ed, Comp.IAcSmComponent component,
            ref Int32 ren_count, Boolean continue_numbering) {
            Array array = null;
            component.GetDirectlyOwnedObjects(out array);
            if (array != null) {
                Int32 sheet_number = 1;
                Boolean basis_of_first = continue_numbering;
                foreach (var item in array) {
                    if (item is Comp.IAcSmSubset) {
                        ProcessElement(ed, (Comp.IAcSmSubset)item, ref ren_count, continue_numbering);
                    else if (item is Comp.IAcSmSheet) {
                        Comp.IAcSmSheet sheet = (Comp.IAcSmSheet)item;
                        String cur_str_value = sheet.GetNumber();
                        Int32 int_value = 0;
                        Boolean is_int32 = Int32.TryParse(cur_str_value, out int_value);
                        if (!is_int32 || (!basis_of_first && int_value != sheet_number)) {
                            sheet.SetNumber(sheet_number.ToString());
                            ++ren_count;
                        else if (basis_of_first) {
                            sheet_number = int_value;
                        ++sheet_number;
                        basis_of_first = false;
                    else if (item is Comp.IAcSmPersist) {
                        Comp.IAcSmPersist persist = (Comp.IAcSmPersist)item;
                    else {
                        ed.WriteMessage("Unknown object: {0}", item.GetType().ToString());
        #region IExtensionApplication Members
        public void Initialize() {
            ed.WriteMessage("\nSheetSetTools. © Andrey Bushman, 2013\n\n");
        public void Terminate() {
            // Empty body.
        #endregion
Message 7 of 13
No. You need ObjectARX SDK 2020 and ACSMCOMPONENTS23.tlb
See attached file.
P.S.: This forum only for ObjectARX (native C++). Ask this question in .NET forum:  https://forums.autodesk.com/t5/net/bd-p/152
Expert Elite Member
Message 8 of 13
@jtm2020hyo
for AutoCAD 2020 should I use this code?
tlbimp acsmcomponents23.tlb /out:Interop.ACSMCOMPONENTS23Lib.dll /namespace:AcSm /machine:x64
Message 9 of 13
Yes. But I've attached above ready for use file: https://forums.autodesk.com/autodesk/attachments/autodesk/34/38519/1/Interop.ACSMCOMPONENTS23Lib.zip
Expert Elite Member
Message 10 of 13
I tried use convert an update version using Visual Basic, but not luck:
tlbimp "C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64\acsmcomponents24.tlb" /out:Interop.ACSMCOMPONENTS24Lib.dll /namespace:AcSm /machine:x64
could help me or teach me how should I do this?
here my error message:
C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64>tlbimp "C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64\acsmcomponents24.tlb" /out:Interop.ACSMCOMPONENTS24Lib.dll /namespace:AcSm /machine:x64
Microsoft (R) .NET Framework Type Library to Assembly Converter 4.8.3928.0
Copyright (C) Microsoft Corporation.  All rights reserved.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.IAcSmFiler.ReadRawData' cannot be marshaled by the runtime marshaler.  Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.IAcSmFiler.ReadBytes' cannot be marshaled by the runtime marshaler.  Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.IAcSmPersistProxy.GetRawData' cannot be marshaled by the runtime marshaler.  Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.AcSmDSTFilerClass.ReadRawData' cannot be marshaled by the runtime marshaler.  Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.AcSmDSTFilerClass.ReadBytes' cannot be marshaled by the runtime marshaler.  Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : warning TI3015 : At least one of the arguments for 'AcSm.AcSmPersistProxyClass.GetRawData' cannot be marshaled by the runtime marshaler.  Such arguments will therefore be passed as a pointer and may require unsafe code to manipulate.
TlbImp : Type library imported to C:\Autodesk\ObjectARX_for_AutoCAD_2022_Win_64bit_dlm\inc-x64\Interop.ACSMCOMPONENTS24Lib.dll
Message 11 of 13
There are only warnings - Interop.ACSMCOMPONENTS24Lib.dll was produced. So you can use it.
Expert Elite Member
Message 12 of 13
https://forums.autodesk.com/t5/net/update-2013-references-to-2022/td-p/10963984
In this post I tried both references, the dll(after use the command) and the TLD source. With both still did not work.
Until remember, in the code in the link exist a duplicate attribute error, and was solved when I used the version 23 reference posted above
Do will is reference not solve the duplicate attribute error?
Message 13 of 13
Are you talking about this error: "Error CS0579 Duplicate 'Rtm.ExtensionApplication' attribute..."  ?
This error not linked with reference of this dll-file. Check all source cs-files in your project...
Expert Elite Member
Autodesk Customer Advisory Groups
