ObjectARX 2020 wizard not working
I have VS 2017 Community 15.9.13 with 'Desktop development with C++' workload plus optional items 'Visual C++ MFC ...' and 'Windows 10 SDK (10.0.17134)' installed (amongst other workloads).
I installed the ObjectARX SDK to C:\ObjectARX2020 and I installed the ObjectARX 2020 wizards using the  ObjectARXWizard2020.msi.
In VS2017, I select New Project, then I select the 'ARX/DBX Project For AutoCAD 2020' template then press OK expecting the project to be created but the New Project dialog is just redisplayed; the project is not created.
Any ideas?
Replies (13)
Alexander.Rivilis
@Anonymous
You have to install ObjectARX Wizard with Admin right's
Š’Ń–Š“ŠæŠ¾Š²Ń–Š“ь ŠŗŠ¾Ń€ŠøсŠ½Š°? ŠšŠ»Ń–ŠŗŠ½Ń–Ń‚ŃŒ Š½Š° "Š’ŠŸŠžŠ”ŠžŠ‘ŠŠ™ŠšŠ£" ціŠ¼ ŠæŠ¾Š²Ń–Š“Š¾Š¼Š»ŠµŠ½Š½ŃŠ¼! | Do you find the posts helpful? "LIKE" these posts!
ŠŠ°Ń…Š¾Š“ŠøтŠµ сŠ¾Š¾Š±Ń‰ŠµŠ½Šøя ŠæŠ¾Š»ŠµŠ·Š½Ń‹Š¼Šø? ŠŸŠ¾ŃŃ‚Š°Š²ŃŒŃ‚Šµ "ŠŠ ŠŠ’Š˜Š¢Š”ŠÆ" этŠøŠ¼ сŠ¾Š¾Š±Ń‰ŠµŠ½ŠøяŠ¼!
ŠŠ° Š²Š°ŃˆŠµ Š·Š°ŠæŠøтŠ°Š½Š½Ń Š²Ń–Š“ŠæŠ¾Š²Ń–Š»Šø? ŠŠ°Ń‚ŠøсŠ½Ń–Ń‚ŃŒ ŠŗŠ½Š¾ŠæŠŗу "ŠŸŠ Š˜Š™ŠŠÆŠ¢Š˜ Š Š†ŠØŠ•ŠŠŠÆ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
ŠŠ° Š²Š°Ńˆ Š²Š¾ŠæрŠ¾Ń усŠæŠµŃˆŠ½Š¾ Š¾Ń‚Š²ŠµŃ‚ŠøŠ»Šø? ŠŠ°Š¶Š¼ŠøтŠµ ŠŗŠ½Š¾ŠæŠŗу "Š£Š¢Š’Š•Š Š”Š˜Š¢Š¬ Š Š•ŠØŠ•ŠŠ˜Š•"
Alexander Rivilis / ŠŠ»ŠµŠŗсŠ°Š½Š“р Š ŠøŠ²ŠøŠ»Šøс / ŠžŠ»ŠµŠŗсŠ°Š½Š“р Š Ń–Š²Ń–Š»Ń–с
Programmer & Teacher & Helper / ŠŸŃ€Š¾Š³Ń€Š°Š¼Š¼Šøст - Š£Ń‡ŠøтŠµŠ»ŃŒ - ŠŸŠ¾Š¼Š¾Ń‰Š½ŠøŠŗ / ŠŸŃ€Š¾Š³Ń€Š°Š¼Ń–ст - Š²Ń‡ŠøтŠµŠ»ŃŒ - ŠæŠ¾Š¼Ń–чŠ½ŠøŠŗ
Facebook | Twitter | LinkedIn
Expert Elite Member
Thank you; that fixed it.
EMD1954
I have this exact same problem with the 2022 Wizard.  I am the administrator.  VS2019 is installed and working properly (I built all 34 of my projects successfully).  AutoCAD 2022 is installed and working properly.  Anything you can suggest for me?
Thanks, Ed
Alexander.Rivilis
Thanks, Ed
1. Download https://github.com/ADN-DevTech/ObjectARX-Wizards/blob/ForAutoCAD2022/ObjectARXWizardsInstaller/Objec...
2. Unblock this file
3. Extract ObjectARXWizard2022.msi to C:\TEMP directory
4. Run cmd.exe as Administrator
5. Run:
msiexec.exe /i C:\Temp\ObjectARXWizard2022.msi
P.S.: If you have installed ObjectARX Wizard 2021 - you can have a problem with ObjectARX Wizard 2022
Expert Elite Member
EMD1954
I uninstalled the ObjectARX 2019 Wizards and restarted the machine.  I followed your instructions and installed ObjectARX 2022 Wizards from cmd.exe.  I restarted the machine.  Same result.  Basically nothing happens when I hit "Create".  I'm using Microsoft Visual Studio Professional 2019, Version 16.11.5.
Alexander.Rivilis
Try ObjectARX Wizard 2021
Expert Elite Member
EMD1954
Sorry, same result.  I uninstalled the 2022 Wizard first, then installed the 2021 Wizard.  I get the attached screen, hit 'create' and nothing happens.  I still have VS2017 (no Wizards) installed.  Could that be the problem?
Alexander.Rivilis
With VS 2019 (16.11.6) ObjectARX Wizard 2022 is working on my side. I also have VS 2017 installed, so it is not a problem.
Expert Elite Member
EMD1954
Alexander,
I updated to Version 16.11.6 and reinstalled the wizard.  Same result.  So I installed VS Pro 2019 on my laptop, updated to Version 16.11.6 and installed the wizard using "msiexec.exe /i C:\Temp\ObjectARXWizard2022.msi".  Says it installs properly but I get the same result.  Is there anything else about my Windows setting that I should be looking for?
Sorry to be difficult,
Ed
dinomyar
Sorry to ask, but did you get this figured out? I am having the same problem with the ObjectArx 2023 wizards, where when I hit create, nothing happens.
EMD1954
No.  I gave up on 2019 and haven't even tried on 2023.  I just make my own projects, files, classes, etc. manually (the old fashioned way).
dinomyar
Thanks for the answer. I will do it manually too. I do not do this often enough to try to figure it out.
tbrammer
Same here. I have installed VS 16.11.19 as only VS version on a new laptop running Windows 10 Pro. I followed all the described steps. The setup always claimed to be successfull. But there is no project template for ARX/DBX apps :-(.
I gave up too and just reuse old projects or the provided ObjectARX samples.
I would really like to find out what's going on here.
Thomas Brammer ā— Software Developer ā— imos AG ā— LinkedIn ā—
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
