If this is incomplete, please let me know.
I made an arx com and I can call from another program, it works fine.
On Autocad 2025 I get this error on my function -> Invoke which return 'exception' :
System.Runtime.InteropServices.SEHException: 'Un composant externe a levé une exception.'
NONE of my COM functions work, I can only launch autocad 2025
client cpp file :
CoInitialize(NULL);
//UUID AUTOCAD 2025
CLSID clsid;
clsid.Data1 = 0x363E5B47;
clsid.Data2 = 0x885D;
clsid.Data3 = 0x44C3;
clsid.Data4[0] = 0x89;
clsid.Data4[1] = 0xeb;
clsid.Data4[2] = 0xa2;
clsid.Data4[3] = 0xab;
clsid.Data4[4] = 0x21;
clsid.Data4[5] = 0x29;
clsid.Data4[6] = 0xb5;
clsid.Data4[7] = 0x7e;
if(::GetActiveObject(clsid,NULL,&pUnk)==S_OK) // Is AutoCAD already open?
erreur("already2\n");
// ...Yes so let's get our interface to the Object Model..
pUnk->QueryInterface(__uuidof(IAcadApplication),(LPVOID*)&acadApp);
pUnk->Release();
else
erreur("new2\n");
hr = CoCreateInstance(clsid, NULL, CLSCTX_ALL, __uuidof(IAcadApplication), (void**) &acadApp);
//acadApp->Visible=VARIANT_TRUE;
AttachCOM();
bool AttachCOM()
bool r=false;
iii=NULL;
for (int i = 0 ; i<16;i++)
__try
__AttachCOM();
r=true;
break;
__except(1)
if (iii!=NULL)
arxObj.AttachDispatch(iii,FALSE);
MessageFilter *in=new MessageFilter();
HRESULT hr = CoRegisterMessageFilter(in,NULL);
else
r=false;
return r;
class MessageFilter : public IMessageFilter
DWORD STDMETHODCALLTYPE RetryRejectedCall(
HTASK hTaskCallee, DWORD dwTickCount, DWORD dwRejectType
return 1000; // Retry in a second
DWORD STDMETHODCALLTYPE HandleInComingCall(
DWORD dwCallType, HTASK hTaskCaller,
DWORD dwTickCount, LPINTERFACEINFO lpInterfaceInfo
return 0; // SERVERCALL_ISHANDLED
DWORD STDMETHODCALLTYPE MessagePending(
HTASK hTaskCallee, DWORD dwTickCount, DWORD dwPendingType
return 1; // PENDINGMSG_WAITNOPROCESS
HRESULT STDMETHODCALLTYPE QueryInterface(
/* [in] */ REFIID riid,
/* [iid_is][out] */ __RPC__deref_out void __RPC_FAR *__RPC_FAR *ppvObject)
return 0;
ULONG STDMETHODCALLTYPE AddRef( void)
return 0;
ULONG STDMETHODCALLTYPE Release( void)
return 0;
void __AttachCOM()
iii = acadApp->GetInterfaceObject(L"servcom2025.iarxobj");
erreur("After 2025");
if (iii == NULL)
erreur("Pas de com installé");
else
erreur("GetInterfaceObject trouvé");
.h file
class Ciarxobj2025 : public COleDispatchDriver
public:
Ciarxobj2025() {} // Calls COleDispatchDriver default constructor
Ciarxobj2025(LPDISPATCH pDispatch) : COleDispatchDriver(pDispatch) {}
Ciarxobj2025(const Ciarxobj2025& dispatchSrc) : COleDispatchDriver(dispatchSrc) {}
// Attributes
public:
// Operations
public:
// Iiarxobj methods
public:
void test458(long test1, long test2)
static BYTE parms[] = VTS_I4 VTS_I4;
InvokeHelper(0x1, DISPATCH_METHOD, VT_EMPTY, nullptr, parms, test1, test2);
.idl file :
// servcom1.idl : IDL source
// This file will be processed by the MIDL tool to
// produce the type library (servcom1.tlb) and marshalling code.
import "oaidl.idl";
import "ocidl.idl";
//import "acadi.idl";
object,
uuid(2BC4C716-450C-493E-BA45-D2ADAC980F3D),
dual,
nonextensible,
helpstring("Iiarxobj Interface"),
pointer_default(unique)
interface Iiarxobj : IDispatch{
[id(1), helpstring("method test458")] HRESULT test458(LONG test1, LONG test2);
//uuid(06B7CCFD-1DA4-43CB-A49F-8F4E1F172E82),
uuid(6CFF8A3B-3843-49B3-9B2F-F91E792E995A),
version(1.0),
helpstring("servcom1 1.0 Type Library")
library servcom1Lib
importlib("stdole32.tlb");
importlib("stdole2.tlb");
//----- If the following import fails then it means that the type library
//----- is not on the system path you can fix the problem in two ways:
//----- 1. Add it to the system wide PATH environment variable
//----- 2. Add it to the executable file list in Developer Studio. You can do
//----- this in using the Tools/Option menu and then choosing the 'Directories'
//----- tab and finally typing the full path at the Executable files section.
//----- Importing english is ok here. Autodesk doesn't localize this idl/tlb.
//----- axdb16enu.tlb is guaranteed to be available in all locales.
//----- If you want to provide localized typelib then you must import
//----- localized tlb here.
importlib("axdb18enu.tlb");
uuid(7C547673-46F4-468D-8048-C70DD5741EAB),
helpstring("iarxobj Class")
coclass iarxobj
[default] interface Iiarxobj;
.rgs file:
HKCR
servcom2025.iarxobj.1 = s 'iarxobj Class'
CLSID = s '{7C547673-46F4-468D-8048-C70DD5741EAB}'
servcom2025.iarxobj = s 'iarxobj Class'
CurVer = s 'servcom2025.iarxobj.1'
NoRemove CLSID
ForceRemove {7C547673-46F4-468D-8048-C70DD5741EAB} = s 'iarxobj Class'
ProgID = s 'servcom2025.iarxobj.1'
VersionIndependentProgID = s 'servcom2025.iarxobj'
ForceRemove 'Programmable'
InprocServer32 = s '%MODULE%'
val ThreadingModel = s 'Apartment'
'TypeLib' = s '{6CFF8A3B-3843-49B3-9B2F-F91E792E995A}'
.rgs file :
HKCR
NoRemove AppID
'%APPID%' = s 'servcom1'
'servcom1.arx'
val AppID = s '%APPID%'
.cpp file for register arx
//- servcom1.cpp : Initialization functions
#include "StdAfx.h"
#include "resource.h"
#include <initguid.h>
#include "servcom1.h"
#include "servcom1_i.c"
#include "acadi_i.c"
#include "iarxobj.h"
//les uuid sont inutiliser dans la base de registre
class Cservcom1Module : public CAtlDllModuleT<Cservcom1Module> {
public :
DECLARE_LIBID(LIBID_servcom1Lib)
#ifdef v2018
DECLARE_REGISTRY_APPID_RESOURCEID(IDR_SERVCOM1, "{45B87C2A-3947-419B-8946-2D9B12CA354A}")
#else
#ifdef v2017
DECLARE_REGISTRY_APPID_RESOURCEID(IDR_SERVCOM1, "{C8B1EB7F-95E2-4145-A846-62308A029FCB}")
#else
#ifdef v2015
DECLARE_REGISTRY_APPID_RESOURCEID(IDR_SERVCOM1, "{3919592B-3BE3-4645-98C4-DE703864F170}")
#else
#ifdef v2013
DECLARE_REGISTRY_APPID_RESOURCEID(IDR_SERVCOM1, "{995057C8-68D5-427A-A2E7-68290086E1DD}")
#else
DECLARE_REGISTRY_APPID_RESOURCEID(IDR_SERVCOM1, "{0F51302A-4EA8-42F9-BCD8-E475AB28F186}")
#endif
#endif
#endif
#endif
Cservcom1Module _AtlModule ;
//- DLL Entry Point
extern "C"
BOOL WINAPI DllMain (HINSTANCE hInstance, DWORD dwReason, LPVOID lpReserved) {
//- Remove this if you use lpReserved
UNREFERENCED_PARAMETER(lpReserved) ;
if ( dwReason == DLL_PROCESS_ATTACH ) {
_hdllInstance =hInstance ;
} else if ( dwReason == DLL_PROCESS_DETACH ) {
return (_AtlModule.DllMain (dwReason, lpReserved)) ;
//- Used to determine whether the DLL can be unloaded by OLE
STDAPI DllCanUnloadNow (void) {
HRESULT hr =(_AtlModule.GetLockCount () == 0 ? S_OK : S_FALSE) ;
return (hr) ;
//- Returns a class factory to create an object of the requested type
STDAPI DllGetClassObject (REFCLSID rclsid, REFIID riid, LPVOID *ppv) {
return (_AtlModule.GetClassObject (rclsid, riid, ppv)) ;
//- DllRegisterServer - Adds entries to the system registry
STDAPI DllRegisterServer (void) {
//- Registers object, typelib and all interfaces in typelib
return (_AtlModule.RegisterServer (TRUE)) ;
//- DllUnregisterServer - Removes entries from the system registry
STDAPI DllUnregisterServer (void) {
return (_AtlModule.UnregisterServer (TRUE)) ;
#ifndef _WIN64
#pragma comment(linker, "/EXPORT:DllCanUnloadNow=_DllCanUnloadNow@0,PRIVATE")
#pragma comment(linker, "/EXPORT:DllGetClassObject=_DllGetClassObject@12,PRIVATE")
#pragma comment(linker, "/EXPORT:DllRegisterServer=_DllRegisterServer@0,PRIVATE")
#pragma comment(linker, "/EXPORT:DllUnregisterServer=_DllUnregisterServer@0,PRIVATE")
#else
#pragma comment(linker, "/EXPORT:DllCanUnloadNow=DllCanUnloadNow,PRIVATE")
#pragma comment(linker, "/EXPORT:DllGetClassObject=DllGetClassObject,PRIVATE")
#pragma comment(linker, "/EXPORT:DllRegisterServer=DllRegisterServer,PRIVATE")
#pragma comment(linker, "/EXPORT:DllUnregisterServer=DllUnregisterServer,PRIVATE")
#endif
Help please
Thank.
Solved by daniel_cadext. Go to Solution.
Shouldn’t
axdb18enu.tlb
be:
axdb25enu.tlb
The caller is .Net? maybe that needs to change from framework to core?
