ObjectARX
Is the length of the curve extension incorrect?
3 REPLIES 3
244 Views, 3 Replies
AcGePoint3d PtO;
if (AcDbObjectId  id = Ctest0lib::SelectEnt(_T("/n选择曲线"),PtO))
  ExtendCurve( id , 1000);
AcDbObjectId SelectEnt(const TCHAR* prompt,AcGePoint3d &PtO)
	ads_name ent;
	ads_point pt;
	AcDbObjectId entId = AcDbObjectId::kNull;
	int ret = RTNORM;
	ret = acedEntSel(prompt, ent, pt);
	if (RTNORM != ret)	return entId;
	acdbGetObjectId(entId, ent);
	PtO = asPnt3d(pt);
	return entId;
static bool ExtendCurve(AcDbObjectId id , double extensionLength)
	bool TF = false;
	AcDbEntity *pEnt = NULL;
	Acad::ErrorStatus es = acdbOpenObject(pEnt, id, AcDb::kForWrite);
	if (es != Acad::eOk) return TF;
	if (pEnt->isKindOf(AcDbCurve::desc()))
		AcDbCurve *pCurve = AcDbCurve::cast(pEnt);
		pCurve->extend(extensionLength);
		pCurve->close();
		TF = true;
	pEnt->close();
	return TF;
Can it be extended in both directions?
3 REPLIES 3
daniel_cadext
in reply to: 1127204185
maybe take into consideration the param WRONG Doh!
import traceback
from pyrx_imp import Rx
from pyrx_imp import Ge
from pyrx_imp import Gi
from pyrx_imp import Db
from pyrx_imp import Ap
from pyrx_imp import Ed
def PyRxCmd_doit() -> None:
    try:
        # create a curve with a length of 100
        db = Db.curDb()
        curve = Db.Line(Ge.Point3d(0, 0, 0), Ge.Point3d(0, 100, 0))
        lineid = db.addToModelspace(curve)
        #check length
        print(curve.getDistAtParam(curve.getEndParam()))
        # extend do start first, does it matter?
        curve.extend(curve.getStartParam() - 1000)
        curve.extend(curve.getEndParam() + 1000)
        #should be 100 + 1000 + 1000
    except Exception as err:
        traceback.print_exception(err)
output:
Command: DOIT
100.0
2100.0
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
tbrammer
The parameter value of a point on an AcDbCurve is in general not the same as its distance from the starpoint!
In case of a polyline the first vertex point has the parameter 0 the second 1 the third 2 and so on.
Unfortunately neither AcDbCurve nor AcGeCurve3d have methods to evaluate the start-/endparameter or the start-/endpoint itself of a curve that is extended by a given length. I tried AcDbCurve::getParamAtDist(dist,..)  and AcGeCurve3d::paramAtLength(dist,...). Both work only if 0<=dist<=curve length.
I think it is best practice to calculate the new start/endpoint yourself based on your requirements and knowledge of the curve. Do you want to extent the curve with a tangential line or shall the extension follow the existing curve?
In the latter case a different approach is to estimate the required parameter value by calculating the "parameter-velocity" at the start- or endpoint:
  curve->getFirstDeriv(parStart, vDeriv);
  velocity = vDeriv.length(); // dLength / dParam
  dParam  = addedLength / velocity;
  parStartNew = parStart-dParam;
  curve->getFirstDeriv(parEnd, vDeriv);
  parEndNew = parStart + dParam;
It seems to work fine if the curve is linear at the start/endpoint. But the velocity may vary in non linear curves.
You could extend the curve multiple times until its total length is  >= old length + additionalLength. Than you can evaluate the "extension point" and cut the curve there.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
daniel_cadext
Thanks for that, I tested on a polyline and it went wonky : |
AutoCAD Inside the Factory
